I'm getting ready to rebuild the brake calipers on my 79. The car has the original calipers with the lip seals and I want to upgrade to the o-ring seals. I understand this requires new pistons, but what about the springs? Can I assume that if the springs aren't broken they're OK? If not, is there a test of some kind to see if they need replacing as well?
Do I have to hone the sleeves? If they have scratches, nicks or other minor damage do I have to replace them (the calipers)? I'm also assuming I have to take the calipers apart to replace the seals and pistons. Is there a torque setting for the bolts that hold the caliper halves together? I haven't taken them off yet, and just wanted to benefit from everyone else's experience before I started. Thanks for any information.
If they are the original calipers they may be rust pitted beyond rebuilding. You will not know for sure until you take them apart. In this thread I posted some pics. of my recent rebuild. With o-ring seals many guys say you do not need any springs. I reinstalled mine, they do push the pistons out just as they did with the lip seals. Good luck with it. mike...
...Do I have to hone the sleeves? If they have scratches, nicks or other minor damage do I have to replace them (the calipers)? I'm also assuming I have to take the calipers apart to replace the seals and pistons. Is there a torque setting for the bolts that hold the caliper halves together? I haven't taken them off yet, and just wanted to benefit from everyone else's experience before I started. Thanks for any information.
From Vette Brakes Torque Specs sheet... http://www.vbandp.com/Tech-Info/ BRAKES Caliper Mounting Bolts, front 70# 5/8" rear 70# 5/8"
Caliper Housing Bolts, front 130# 13/16" rear 60# 5/8"
If you go here, http://www.vbandp.com/How-To-Video/how-to-video.html and click on the C2/C3 Brakes Video VB&P also has a video that will take you through a brake job on a C3. If you've done this a few times it may seem a bit more for a novice, but it's also a good refresher if you haven't done this job in a while.
If they haven't been sleeved you will save yourself trouble down the road by either having them sleeved or getting a set of sleeved calipers. Let me know if we can help with that.
The un-sleeved calipers function just fine. The difference is that the stainless sleeved calipers are 'immune' to absorbed moisture in the brake fluid...they won't rust/pit due to moisture. And, if your car is used regularly and brake fluid is not allowed to get old (fluid refresh every few years), non-stainless calipers won't rust/pit, either.
If you need to replace your calipers due to damaged/rough bores or wear, get the sleeved replacements. Otherwise, it's up to you to justify replacing them with 'better' hardware. Remember, when replacing any calipers, replace them in pairs (fronts and/or backs) to the brakes are evenly 'balanced'. If you only need one caliper replaced, do so with the identical configuration as its 'mate'.
I seriously doubt that unsleeved calipers on a C3 that has not had the brake fluid changed every 1-2 years from when the calipers were new from the factory would be serviceable today. The caliper design makes them highly susceptible to moisture corrusion, much more so than standard calipers on most cars yesterday and today. You might as well just change the calipers to SS ones since most likely the change would be coming at some point down the road anyhow. Just my 2 cents!
In that old post members are talking about AutoZone and lifetime warranty calipers. NO MORE. They offer a 1 year warranty with only one replacement available during that period. I called all the other big box cheapie stores and they have all unfortunately smartened up. What's a cheap b*stard to do?
Still the best deal.
The ss liners won't fail from corrosion. Some time in the future, just replace the seals with a oring piston set (30 bucks/wheel) and after that you will probably need orings only.
Keep the fluid flushed every 2 years.
I just rebuilt my stainless steel sleeved rear calipers - (lasted 20 years) with the new pistons and O ring seals. (From Vette Brakes).
When inserting the new pistons with O Ring seals they seemed very tight while inserting em into the bores. The bore was coated with brake fluid as was the piston and seal dipped in brake fluid upon insertion. I installed the springs as well.
I can insert them in the bores and they go all the way in but don't "Spring back" like the old lip seals used to. They stay at bottom. In fact pulling them out again requires some pulling/finessing etc. The bores are stainless and are perfectly smooth.
Is this normal with pistons with O ring seals? Will they work themselves in after they are put back into use?
Has anyone else had this experience with the new pistons and o ring seals?
Don't worry about them not springing back, in fact most of the directions I have seen for them say not to install the springs at all.
There isn't much movement of the piston at all once the system is bled and used, only a few thousandths. They don't drag the rotors like the lip seals.
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
So, who has the best deal on just outright buying a new or rebuilt set (all 4 corners) with the SS sleeved O-rings? I'm in the market but can and will wait on a "sale" to push me off the fence. Anyone?
Vette Brakes or Corvette Stainless Steel Brakes + all the Corvette aftermarket parts Suppliers. I also understand that the local parts stores like O'Riley, Autozone and PepBoys carry them as well....good luck!
I'm pleased w/ Lonestar ... mine from local shop ... not much more than advance ap ... LCC warranty as good as it gets. Gravevine says lotsa big name vette specialty houses get theirs from LCC.
You don't have to wait, we're running a special right now for 5% off on calipers. $379.95 for set of four O-ring calipers with pads (exchange) comes to $360.
