What a difference !!
Old Apr 13, 2002 | 11:24 AM
Jon69L46's Avatar
Jon69L46
Default What a difference !!
With the high compression engine in my L-46, I always have to mix something in the gas so I don't ping. I don't like to retard the timing at all, and loose some of the performance. Most of the time I mix in a couple of gallons of 110 octane racing gas and it runs pretty well.
But every once in a while I run over to the next county, they have a gas station that pumps 104 octane. Remember that? They sell it as racing gas too. Besides the fact that it's just plain nice to pull up to a pump and not have to mix this and that..........Man what a difference, it runs absolutely great. Much more responsive and alive!!
What a shame it's so d*** expensive. (4.00 gal )
Jon
[Modified by Jon69L46, 7:26 AM 4/13/2002]
Old Apr 13, 2002 | 11:33 AM
Fevre's Avatar
Fevre
Default Re: What a difference !! (Jon69L46)
Price you pay to be a muscle car owner.:cry
I love my 8.5 /1 87 octane user......for now. I am going to go back to the 10/1 stroker. I miss the power but not the fill ups. :)
BTW Which engine do you have and what compression. I am guessing the 11/1 370 horse LT-1
Old Apr 13, 2002 | 11:44 AM
Jon69L46's Avatar
Jon69L46
Default Re: What a difference !! (Fevre)
I know, but the ride back are the benefits. Some beautiful cruising rodes in here northern CA . The L46 is the 11.0-350 hp version.
Jon
Old Apr 13, 2002 | 12:12 PM
Fevre's Avatar
Fevre
Another bright side: light wallet makes you faster. :lol:
Happy cruisen' bro.
Old Apr 13, 2002 | 12:20 PM
shawn_cake's Avatar
shawn_cake
Lead Supreme 130 from Kemco Oil in Lehi utah.
This stuff really works..
http://www.kemcooil.com/fueladditives.html
This is a direct cut and paste from the Kemco Oil WWW Site (fuel additives section)
LEAD SUPREME-130
GAS TREATMENT
DATA/FACT SHEET
WHAT IS LEAD SUPREME-130
A GENUINE TETRAETHYL LEAD (TEL) gasoline treatment. Since 1921, TEL has been the original additive that (1) Boosts octane numbers, (2) Eliminates engine knock, and (3) Protects valves and valve guides. Only with TEL can you expect the highest performance in these three crucial areas.
WHY IS LEAD SUPREME-130 DIFFERENT FROM ALL THE OTHER ADDITIVES ON THE MARKET TODAY?
Lead Supreme-130 contains a high level of genuine tetraethyl lead. Other manufacturer's additives contain lead substitutes, such as Ammonium Phosphates, Amine Phosphates, Manganese compounds, Sodium, Sulfur formulas, and others.
There are products that blend a trace of lead with other chemical substitutes, so they advertise a lead product. Lead Supreme-130 is the only product with 100% TEL activant (NO SUBSTITUTES) for maximum performance.
IS LEAD SUPREME-130 SAFE FOR THE ENVIRONMENT?
By adding Lead Supreme-130 to your fuel, your engine will perform better by increasing horsepower and burning the fuel more efficiently. Practically all the lead content is burned and deposited on the valves and valve seats, leaving the environment virtually lead free. The sun quickly decomposes any remaining trace of lead.
HIGHLIGHTS OF LEAD SUPREME-130
1. The only product with 100% Tetraethyl Lead and other octane enhancing components (No substitute chemicals added).
2. Boosts octane from 2-16 points when added to fuel. Perfect for HIGH COMPRESSION ENGINES. Eliminates engine knocking.
3. Protects valves and valve guides.
4. EPA registered.
5. Environmentally safe
6. A superior gasoline treatment.
TREAT RATES R+M/2
0.6- Ounces LS-130 to 1 gallon/fuel……….2.0 point octane increase
1.2- Ounces LS-130 to 1 gallon/fuel……….3.5 point octane increase
1.8- Ounces LS-130 to 1 gallon/fuel……… 5.0 point octane increase
2.4- Ounces LS-130 to 1 gallon/fuel……….6.5 point octane increase
3.0- Ounces LS-130 to 1 gallon/fuel…….…8.0 point octane increase
6.0- Ounces LS-130 to 1 gallon/fuel……..11.0 point octane increase
18- Ounces LS-130 to 1 gallon/fuel……..16.0 point octane increase
Kemco Oil & Chemicals
Lehi, Utah
:cool: :cool: :cool: :cool:
[Modified by shawn_cake, 9:23 AM 4/13/2002]
Old Apr 13, 2002 | 12:35 PM
Jon69L46's Avatar
Jon69L46
Default Re: What a difference !! (shawn_cake)
Yeah......I've followed that link before, was thinking about it. Do you figure a can, to a 10gal tank, to get it from 91-to say 98 ?
Jon
Old Apr 13, 2002 | 02:24 PM
shawn_cake's Avatar
shawn_cake
The mix ratios are in my previous message. They are directly from the Kemco Oil web page. They are good folks - drop them an e-mail and they can help you figure out what to do.
The other octane boosters are just snake oil.
This stuff is real tetra-ethyl lead - it works. BUT - it will ruin 02 sensors and catalytic convertors.
When you receive your delivery of Lead Supreme 130, read the safety instructions - follow the safety instructions! No shortcuts - just follow the safety instructions!
Lead Supreme 130 is very poisonous - wear good quality rubber gloves when handling this stuff. Also be sure to wash your hands VERY WELL after handling this stuff. Only work with Lead Supreme 130 OUTDOORS. It can cause poisoning from breathing the fumes!
[Modified by shawn_cake, 11:26 AM 4/13/2002]
To What a difference !!
