As long as I'm replacing the wrong-year shifter console on my 68, I figured I'd sort out the heater controls.
My left heater control wheel has never wanted to go up toward Off because of the cable being broken due to the flapper being stuck - no big deal I'll figure that out.
However I can NOT figure out what purpose the vacuum control valves serve. I don't see ANY heater or air-flow related vacuum solenoids in my car. Everything is cable-actuated.
Nothing, I'd guess that the wrong year shifter plate included the heater controls that you have.
Starting in '69 and possibly for the rest of the C3 series( I'm not sure ) the heater/defroster controls used vacuum as well as cables. There was an actuator located on top of the heater housing that the '68 doesn't have.
I might have a '68 heater control if you'd like the correct parts. You can buy the controls repo'd as well. Check with Willcox.
I just wanted to add that the settings are different on the '68.
You have a vacuum distribution manifold on the left side of the heater control head. It 'sends' vacuum to the damper door servos so that appropriate ducting is selected when the left (function selector) wheel is moved. That is how heater or vent air is directed to the "heat" and/or "de-fog" outlets.
That vacuum distribution valve eliminates the need for additional solenoid valves.
I just double-checked and it definitely has the 1968 heater control markings but has the 2 vacuum manifolds with hoses that from what I can tell are hooked up but lead to nowhere.
The guy who did the restoration work on my 68 was a moron.
You need to have a copy of the Chevrolet Chassis Service Manual for your year car. Section 1A has all the info on your heater/vent controls and where vacuum lines are routed.
I will pick that up. I had an AIM but it's at my parent's house.
I apologize if I gave incorrect info but I don't remember any vacuum involved on either of my non-air '68s and I just replaced my heater controls last summer.
I'd appreciate a picture of a '68 if anyone has one.
DZRick I am inclined to believe you are correct. I can't find any heater/cooling/damper related actuator of any kind. If there's no actuator, what would I ever need vacuum for.
Furthermore, the mechanical cables seem to actuate all the arms and functions of the ducting that I can think of.
Is it possible that the heater controls are correct for '68, but someone attached a '69-later vacuum manifold to it thinking it was necessary?
As I said before, from my cursory inspection, the hoses connected to the manifold simply go nowhere.
I'm know mine was all cable operated and that there was no vacuum manifold on either of them or the repo controls I bought.
All the setting/lettering is on the lens, your lens might have been swapped from a '68 onto a later year heater control in your case, it's easy to swap the lens.
...I thought it was this way too when I did my heater core and heater control switch system on my '68 convertible a decade ago.
...thought the '68 was the only C3 to be this way?
...when I changed my old '75 coupe to an A/C DELETE car, I made sure to have a '69 & up inner heater box and controls for this very same reason.
