Transmission change
Old Feb 28, 2011 | 12:23 PM
Bob B.'s Avatar
Bob B.
Default Transmission change
I have a 69 vette, 350 engine, 4 speed trans. I can get a 5 speed T5 trans out of an 87 mustang that is in very good condition for a very good price. Has anyone done this or does anyone have any suggestions.
Old Feb 28, 2011 | 04:02 PM
Corey_68's Avatar
Corey_68
I think a couple here have made the swap, I'm sure they will chime in. Just becarefull with the transmission as it has a very low power rating. GM didn't offer th T5 as an option for the 225hp 350ci Camaro in the 1980's as they felt it was too weak and the 350 would tear it apart. Only the 305 was available with this tranny.
I think if you have a stock/mild 350 and don't dump the clutch you will be fine.
Old Feb 28, 2011 | 04:39 PM
Bob B.'s Avatar
Bob B.
Default Trans Change
Corey,
Thanks for the info -- if I were to make this change -- any input on bell housing, clutch, drive shaft --
and
will the shifter line up without messing up the car --
Old Feb 28, 2011 | 05:24 PM
tfi racing's Avatar
tfi racing
Here ya go....
http://forums.corvetteforum.com/c3-t...n-t5-swap.html
Old Feb 28, 2011 | 06:12 PM
Gordonm's Avatar
Gordonm
You guys are all talking about the T5 from a GM car. He wants to buy the Ford T5. I don't think the Ford unit will fit due to the input shaft difference.
To Transmission change
