clutch / trans problems
Old Feb 28, 2011 | 02:12 PM
bucksy99's Avatar
bucksy99
Default clutch / trans problems
I am working on a 75' that has not been started for 7 years. I got the engine running and the cooling systems works now. I finally got the brake system done over the weekend.
Today I started it up and shifted through the gears. It didn't engage and when I took my foot off the brake nothing happened.
I would assume that the clutch is stuck after all these years or is the (automatic) trans itself?
Any input is appreciated.
Old Feb 28, 2011 | 02:21 PM
...Roger...'s Avatar
...Roger...
Low fluid level ?
Old Feb 28, 2011 | 02:33 PM
bucksy99's Avatar
bucksy99
Thanks but fluid should be good.
just changed transmission fluid and filter a few weeks ago.
Old Feb 28, 2011 | 02:52 PM
...Roger...
You can't be sure the level is correct until you start the engine.
To clutch / trans problems
