Which Transmission???
Old Mar 1, 2011 | 08:28 PM
black75's Avatar
black75
Default Which Transmission???
I am just throwin' this out there. I have a 75 coupe with a crate 350/300 and a four speed. It has a super T-10 2.64 first gear with a 3:08? rear. The T-10 in the car is popping out of second which means rebuild time. I picked up a Muncie M-20 wide ratio from a 74 cheap and I am wondering what I should do. Should I pull the T-10 and rebuild it or rebuild the M-20 and put that in the car. Will my brand new Hurst shifter work with the M-20. Opinions are what I am looking for and don't worry about hurting my feelings. Thanks!
Old Mar 1, 2011 | 10:59 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Your first gear will be about 5% taller, but I'd go with the Muncie if you feel you have enough reserve bottom-end torque to make up for it. Nothing against the BW, but IMOE I just like Muncies better. The shifter should work with either transmission. Of course, replacing a 3.08:1 with a 3.55:1 FDR would wake that thing up a bit more.
Old Mar 2, 2011 | 07:04 AM
7T1vette's Avatar
7T1vette
You may be 'popping out of gear' because the linkage arms, bushings, and/or the shift mechanism in the shifter is worn/damaged. There may be no problem with the tranny at all. Evaluate this before you dive into the "money pit".
Old Mar 2, 2011 | 07:24 AM
bashcraft's Avatar
bashcraft
Originally Posted by black75
The T-10 in the car is popping out of second which means rebuild time...
Sounds to me like you need to adjust the shifter linkage.
Old Mar 2, 2011 | 07:32 AM
black75's Avatar
black75
The linkage is adjusted properly, but thanks for the thoughts. I can rebuild either of them myself so the money pit thing should be easier to avoid. The motor has 385 ft.lbs. according to the GM spec sheet. anyone else want to weigh in?
Old Mar 2, 2011 | 08:11 AM
arcticcatmatt's Avatar
arcticcatmatt
5 speed
Old Mar 2, 2011 | 11:17 AM
black75's Avatar
black75
Great idea....you payin'?????
Old Mar 2, 2011 | 11:37 AM
OMF's Avatar
OMF
Is there any chance the shifter boot is old and stiff,.....making it pop out of gear??
Old Mar 2, 2011 | 03:22 PM
dochorsepower's Avatar
dochorsepower
Yes, the BW's will pop out of gear if they're getting worn. I recently had my S-T10 rebuilt and used torque-lock syncros, now no problem popping out of any gear. More importantly, check the condition of the gears before you decide about rebuilding. Synchros are relatively cheap but if you have to start buying replacement gears they are expensive.
Old Mar 2, 2011 | 03:30 PM
myoriginal77's Avatar
myoriginal77
Sell them both and get a T56 - 6 speed, 2000 rpm = 80 mph w/ 4:10 rear gear - Fun on both ends !
Frank
Old Mar 2, 2011 | 03:50 PM
ajrothm's Avatar
ajrothm
Keep the ST10 and rebuild it. Better 1st gear ratio and handles more power then the M20/M21. Not to mention you already have a new shifter. If you think you may want overdrive in the future, now is the time to upgrade.
To Which Transmission???
