Brake lights not working.
Old Apr 13, 2002 | 07:48 PM
Paul 73 Coupe's Avatar
Paul 73 Coupe
Default Brake lights not working.
Any ideas why the brake lights wont go on but the turn signals work fine? I also checked the switch at the pedal which seems to be working. Fuse panel is good....Arghhhhhh :confused:
Old Apr 13, 2002 | 09:28 PM
jerryp58's Avatar
jerryp58
Default Re: Brake lights not working. (Paul 73 Coupe)
It really sounds like it would be a switch problem, but you may want to check your wiring harness. At some point in its life, mine fell onto the muffler and a lot of wires burnt.
Old Apr 13, 2002 | 09:40 PM
dogboy's Avatar
dogboy
Check the bulbs. Maybe 1 element is burnt out. I also had a wire dangling that was touching the exhaust pipe & would cause an intermittant problem. Check for insulation failure in those spots. also sometimes just wiggling things around can loosen up debris that can cause bad grounding
Old Apr 13, 2002 | 09:43 PM
Paul 73 Coupe
Default Re: Brake lights not working. (jerryp58)
I took the switch out of the equation by jumpering it. I tested 12.35 volts to one side of the switch. Arghhhhhh and it is a nice day. :confused:
Old Apr 13, 2002 | 10:18 PM
Paul 73 Coupe
Is there anything to do with the tail lights in the steering column? I found one wire not connected from my steering column harness. It is a ground wire. :confused: :confused: :confused: :confused:
Old Apr 13, 2002 | 11:31 PM
Paul 73 Coupe
Got it :cool: It was the one wire on my steering column. Thanks for the help.
To Brake lights not working.
