Has anyone moved temp. sending unit.
Old Mar 3, 2011 | 04:08 PM
trainor's Avatar
trainor
Default Has anyone moved temp. sending unit.
When I installed my Brodix heads I lost my spot to put the water temp sending unit in. I installed it into the 1/2 opening in the Performer intake. Problem is that cause its so close to thermostat that my gauge is constantly changing and never seems to settle in a t a good 200 deg or cooler. Anybody got any solutions or have had the same situation. Thanks
Old Mar 3, 2011 | 04:25 PM
trainor's Avatar
trainor
Can anybody give me some input, Please!
Old Mar 3, 2011 | 04:29 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I switched the input location on my '78 from the LH head to the right side of the intake manifold. I would have used the left side of the intake, but there was not adequate clearance from the outlet hose. It was easy to add in a wire extender from the left side wire to the new right side location.
Old Mar 3, 2011 | 05:22 PM
trainor's Avatar
trainor
On my intake the Lh side is 1/2 inch and the Rh side is 3/8. Was yours that way too or different. Also when you did that did it give you good solid reads or did it bounce back and forth with the thermostat?
Old Mar 3, 2011 | 05:32 PM
redman76's Avatar
redman76
St. Jude Donor '09
I have Brodix IK200 with Performer RPM QJet manifold. Here is my setup and it works great. I just had to extend wire to other side of motor.
Old Mar 3, 2011 | 05:39 PM
trainor's Avatar
trainor
The only problem is that the LH side is 1/2 pipe thread and the side you put your on is 3/8 inch on my performer.
Old Mar 3, 2011 | 06:08 PM
redman76's Avatar
redman76
St. Jude Donor '09
It was the same size on mine, so an easy move for me. I'd think you could get an adapter from the h/w store?
Old Mar 3, 2011 | 06:45 PM
trainor's Avatar
trainor
No nothing that will work cause I'm going from a large pipe to a smaller hole and the sender will not fit. I'm going to drill the 3/8 side out to 1/2 and tap it. Thanks for the help
Old Mar 3, 2011 | 09:18 PM
larrywalk's Avatar
larrywalk
My sensor is 1/2" NPT; the threads in my Performer RPM were the same if I recall correctly; but if they weren't, it's very easy to drill and tap for the 1/2 NPT.
My installation looks like trainor's.
To Has anyone moved temp. sending unit.
