68 wiper motors
Old Mar 4, 2011 | 10:13 AM
tomgallucci57's Avatar
tomgallucci57
Default 68 wiper motors
anybody ever buy a wiper motor from autozone for there 68,and did it actually plug right in and work correctally,thanks
Old Mar 4, 2011 | 09:56 PM
76yellow's Avatar
76yellow
No I haven't , but the 68 wiper motor is "68 only" so if their computer says the part number is for other years also, it's not the right wiper motor. Many 68 parts are 68 only. You would be better served going to Willcox (a forum supporter) for something as special as a wiper motor.
Old Mar 5, 2011 | 11:08 AM
tomgallucci57
hello 76,ya im aware of the 68 only issue on most parts,and i really doubt autozone will be the answer.i always deal with willcox,they are always very helpful.but i will call to see if it fits other years,then ill have more info,good idea 76,thanks,tom
Old Mar 5, 2011 | 03:21 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Have you bench tested the motor yet? I've always maintained that 95 percent of the cores returned to us are good working motors!
I have a video on how to test this motor... http://forums.corvetteforum.com/c3-g...d-69-72-a.html I just bumped the thread in case.
And.... thank you for the kind words...
Willcox
Old Mar 6, 2011 | 11:10 AM
tomgallucci57
hi earnie,no i havent tested the motor yet,but i was told from p.o. that it does work.im still looking for that elucive terminal board,with no luck.plus im doubting i would be able to properly install it,so i was hoping someone might have tried an autozone motor,and had good luck with it. it would make my search easier and cheaper with a local store.but in the end,im sure ill be getting one from you guys. thanks again,talk to you soon, tom
Old Mar 6, 2011 | 02:09 PM
0Willcox Corvette
Former Vendor
Tom-
You should be able to find this on just about any old style wiper motor from say 1968-1975 passenger car. If its the resistor that damaged you can just replace it. You just have to be careful not to melt the plastic that holds the terminals when you solder it in place.
Willcox
To 68 wiper motors
