o-ring piston question
Old Mar 6, 2011 | 10:37 PM
biscuitville's Avatar
biscuitville
Default o-ring piston question
I have read in several threads that when using o-ring style brake caliper pistons/seals, the springs should be left out. Why leave them out?
Old Mar 7, 2011 | 05:44 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
when I opened a new o-ring caliper I found that they used a spring in there, been on the car for few years now with no problems at all, so I guess its OK to use the spring.
Old Mar 7, 2011 | 07:11 AM
Brooklinite's Avatar
Brooklinite
The fit is much tighter with the o-rings. You could use the spring but likely wouldn't provide enough pressure to move the piston anyway.
Old Mar 7, 2011 | 06:02 PM
Scott Marzahl's Avatar
Scott Marzahl
The piston will not move with the force provided by the wimpy spring with O rings like it will with standard lip seals. I left the springs out when I rebuilt mine.
Old Mar 7, 2011 | 07:16 PM
wcsinx's Avatar
wcsinx
Exactly
I think they just include them in the o-ring kits because it's cheaper than answering the phone calls from ppl wondering where their springs are. See for yourself. Install them with and without while the caliper is off. They don't generate near enough pressure to move a o-ringed piston.
Old Mar 7, 2011 | 09:48 PM
biscuitville
Thanks for the input everyone.
To o-ring piston question
