I removed the upper control arms and had new bushings installed and not sure which is left hand and which right hand. Can someone please post a picture of a correctly installed upper control arm on a 73
You will find that a correctly installed upper control arm will have the mounting surface for the ball joint (roughly) level with the ground and parallel with the top surface of the spindle. If you reverse L & R, the ball joint mounting surface will be tilted quite a bit. Also, your caster angle will be miles from where it needs to be.
The longest edge of the control arm is facing towards the front of the car.
Thanks for the information I believe I can figure it out based on the information provided but if somone has a photo they could post I would be greatfull.
