Transmission question
Old Mar 8, 2011 | 03:02 PM
Cheech85's Avatar
Cheech85
3rd Gear
Default Transmission question
I have a '79 that I put a 383 in. I'm having problems with the transmission leaking and I can't seem to get it to stop. Its the original TH 350. I replaced the pan gasket and the other seals(forward, back and speedo seals). I am thinking of just rebuilding it and putting a shift kit in while it's apart or buying a new tranny, maybe something with four speeds. Thoughts???
Old Mar 8, 2011 | 03:38 PM
929nitro's Avatar
929nitro
I would change it out with either a 200 4R or a 700R4, but that's me. How many miles on your original tranny?
Old Mar 8, 2011 | 03:41 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Where is the leak coming from?
The first step in correcting it is knowing whats leaking.
Old Mar 8, 2011 | 03:44 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
do not over tighten the pan gaskets thats the surest way to make them leak....i actually use torque wrenchs when i tighten mine....also a big cuprit for leaking is the shift down cable the black plastic body always seems to leak.... un bolt this at the trans and pull it out slightly clean it and use some gasket sealent on it and gently push it back down and tighten it back up..... this fixes most of those leaks
Old Mar 8, 2011 | 04:17 PM
Cheech85's Avatar
Cheech85
3rd Gear
I'm not quite sure where exactly the leak is coming from, it's been garaged all winter. It has about 78k miles on the tranny
To Transmission question
