Carb gurus? Help??
Old Apr 14, 2002 | 05:35 PM
DollaGreen's Avatar
DollaGreen
Default Carb gurus? Help??
Just bid on this item...hope this will work for me. "You are bidding on a Rochester quadrajet carburetor number 7043201. This was an original carb for 73 454 Big Block. This unit has been modified to fit Small Block High Performance engines. It has the Small Block throttle lever so auto trans can also be hooked. This is a 750 CFM carb that has #77 jets, 48B rods and BG secondary rods. This carb has a fresh rebuild and features re-dyed castings, refinished aluminum base, bronze bushings in throttle shaft, resurfaced mounting gasket area, new parts include primary throttle plates, Delco needle and seat, float, secondary metering rod cam, choke pulloff and fuel resistant accelerator pump. A nice carb with plated parts. Comes with mounting gasket and air cleaner gasket. "
Could someone tell me more about the rods and jets, and how they should work with my almost stock setup???
