Heli-Coil Help
Old Apr 14, 2002 | 09:59 PM
bence13_33's Avatar
bence13_33
Default Heli-Coil Help
While bolting my flywheel to my crank I discovered a stripped out bolt hole. Is it alright to put a heli-coil in the crank for this application or is this a no-no? I really see only a few alternatives:
A. Drill the hole out and heli-coil it
B. Drill the hole out, tap it and use a larger bolt
C. Buy a new crank.
Surely I don't have to buy a new crank because of one stripped out bolt hole :(. I had plans of setting up my clutch and bellhousing and dropping the motor in tonight...but it appears as though it will be another day or so.
P.S. I stripped down my engine bay and painted it....boy does it look purdy :).
Old Apr 14, 2002 | 11:26 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Heli-Coil Help (bence13_33)
I'm not an expert by any means, but I'm not sure I'd use a heli-coil on a flywheel bolt. I think I'd drill out the hole and retap it to a slightly larger size.
Old Apr 14, 2002 | 11:32 PM
Scott78's Avatar
Scott78
Thats a tough one. I've used heli-coils in lots of situations but never on a crank. If done right I'd have no problems trusting the strength. Another is to weld it up and redrill and tap. Bigger bolt :nono: , I'd be interested to hear how someone else has fixed theres.
Scott
Old Apr 14, 2002 | 11:39 PM
Pete79L82's Avatar
Pete79L82
I would not drill it out and use a larger bolt. There is the possibility that the couple of extra ounce of weight of a larger bolt could cause a vibration.
As long as the other bolts and thread are in good shape to except being torqued I would put in a heli-coil. Be sure there is a dowel pin in the crank to align the flywheel. Between the dowel pin and the other bolts I don't think you would have a problem with the one that is heli-coiled.
bence13_33's Avatar
bence13_33
I think ddn had a similar problem with his crank. ddn are you out there, how did you fix your stripped out thread on your crank?
Pete:
The crank has a dowel and the flywheel is externally balanced and can only be placed on one way. I agree, I don't see why a heli-coil wouldn't work on one bolt.
[Modified by bence13_33, 9:42 PM 4/14/2002]
Old Apr 14, 2002 | 11:42 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
A heli-coil will be fine, it yields an equivalent or greater strength when compared to the original threads.
Old Apr 14, 2002 | 11:53 PM
Pete79L82's Avatar
Pete79L82
Bence;
When i put aluminum blocks together all the head bolt holes and main cap bolts holes are heli-coiled so I really don't think that one for the flywheel would be a problem. I would use loctite on the heli-coil and all the flywheel bolts.
If you tried drilling it out you would also have to drill the flywheel and I think that could cause you problems.
[Modified by Pete79L82, 9:53 PM 4/14/2002]
Old Apr 15, 2002 | 12:12 AM
redvetteman's Avatar
redvetteman
Use the Heli Coil it will work great. I used it on three head bolts on a 396 big block and used the engine for years.
Old Apr 15, 2002 | 12:35 AM
bence13_33's Avatar
bence13_33
Default Re: Heli-Coil Help (redvetteman)
Thanks for the help guys. I'll stop by my local auto supply shop tomorrow and pick up a(nother) heli-coil kit. Bob I must say that is a very sharp looking '67 you have there!
Old Apr 15, 2002 | 01:49 AM
MYPET70's Avatar
MYPET70
:yesnod: :yesnod: :yesnod: YES, absolutely, use the helicoil kit that'll allow you to using the originally sized bolt. I had this exact same situation happen to me in the 1980ish timeframe on my '70 and it's still holding strong as ever. You will not have a problem with this approach.
Couple tips: 1) spend the money to buy a brand new drill bit in the exact size recommended in the heli-coil kit. The kit will not come with the bit you need. 2) use what I call a "slow speed" or "geared down" .5" drill and do your best to get the bit square with the crank flange. 3) watch carefully how deep you install the heli-coil...make sure you stop screwing it in as soon as the trailing edge of the coil disappears past the face of the crank flange and is slightly recessed. Then you can break off the coil's installation 'tang'
I was SOOO... nervous when I was doing mine because it was the first time my tranny had been removed, I was under the car in the dark, that was my only transportation at the time and the last thing I wanted to have to do was replace the crank...especially under those circumstances. Just use the regular amount of care and attention to detail and you'll feel GREAT when it's finished! :cheers:
Old Apr 15, 2002 | 02:01 AM
ORVette's Avatar
ORVette
Default Re: Heli-Coil Help (gsk@sprintmail.com)
Bence,
I have 10 heli-coiled head bolt's on one deck because of a stupid mistake with the wrong profile thread tap, and they are holding 100%.
Old Apr 15, 2002 | 10:16 AM
Tom454's Avatar
Tom454
Default Re: Heli-Coil Help (ORVette)
Don't forget to assess the length of the insert you need... they come in different lengths.
You need the proper thread engagement.
Autoparts stores typically carry a "common" length, which may not be long enough for your application.
FYI
Tom
To Heli-Coil Help
