Rear Main Install ?
Old Mar 12, 2011 | 03:16 PM
sly vette's Avatar
sly vette
Default Rear Main Install ?
I'm wondering why in all the threads I've read on installing the rear main seal(Fel-Pro #BS-11829-1) in a 350 cid., there is no mention of installing the seal with a 3/8" offset from the flats of the bearing housing/block as is mentioned in the installation instructions?
Should I install it as the instructcions suggest or flush with the flats?
Just curious....
Old Mar 12, 2011 | 03:45 PM
OMF's Avatar
OMF
I think offsetting the mail seal with the block is a personal preference thing only. I have installed several seals on different engines, and I installed them even with the block parting lines, and no leaks so far. I also think that ensuring you place a very small dab of sealant on the seal ends really helps seal off oil leaks....
Old Mar 12, 2011 | 03:49 PM
rcread's Avatar
rcread
Rotate it so it's not flush. That's what I do, and what I've seen professional engine builders do.
Old Mar 12, 2011 | 06:46 PM
Indiancreek's Avatar
Indiancreek
I offset with a small dab of black rtv on the ends. Works well for me.
Old Mar 12, 2011 | 07:46 PM
sly vette's Avatar
sly vette
I installed it as the instructions suggested with a small offset.
I also used the Fel-Pro 1 pc. dry gasket... Great Part!!!
I ran it for 1/2 hr. and no more leaks!
Sure was different than when I worked on cars for a living 35 years ago. The last time I did a rear main it was with a piece of braided material that had to be installed with a braided mesh tool with a TEE Handle.
Things sure have changed!!! FOR THE BETTER!!!
Old Mar 12, 2011 | 08:07 PM
G-Sting's Avatar
G-Sting
Here is a write up with pics of a rear main seal replacement. Any comments from those experienced doing this are welcome.
Old Mar 13, 2011 | 11:24 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Never leave a new installed seal dry!
U need to oil/lube the seal also. Most shade tree mechanics install their seals left dry and have drip again within a short time. A dry seal will wear out right on start-up.
Another miss is the rear main cap needs a specialty sealer to mate to the block. Surprising how many rear main cap go back on w/o sealer to block surface - that's another leak above the pan but looks like the rear seal is still leaking.
U have to sort things out for yourself here on the faceless internet. But really pays to read the instructions first and bounce it off the internet advice.
I have tried every time i respond to a rear seal post to explain offsetting the seal. It is easy to physically do but difficult to type out the explanation. And how do u explain using enough sealer on the matting ends but not leaving any sealer on the seals contact surface with the crank?
Thx for sharing,
cardo0
Old Mar 14, 2011 | 05:51 AM
Indiancreek
cardo0 is spot on with info.
Old Mar 14, 2011 | 09:15 AM
kdf1986's Avatar
kdf1986
G-Sting,
thanks for the write up and photos. I have a leak on one of mine and when I get to the point of replacing the gasket I plan on printing out your instructions and photos as a guide.
kdf
Old Mar 15, 2011 | 07:59 AM
G-Sting's Avatar
G-Sting
Originally Posted by kdf1986
G-Sting,
kdf
kdf: I wish I could claim the write up here, but I cannot. Looks very good, though, from all the inputs here and from other threads on rear main seal install. Nice to have pictures, too. I may be doing mine in the next couple of weeks as well.
sly vette: Great to hear all went together well and no leaks!! Thanks for starting this thread. Good tips from all.
Old Mar 15, 2011 | 11:56 AM
69vettester's Avatar
69vettester
It is a real good idea to tap the 2 piece seal lightly to position it out of alignment with the flats. The 2piece seal can also be shelved for a 1piece. More difficult to install, but not bad.
Old Mar 15, 2011 | 01:47 PM
20mercury's Avatar
20mercury
Thx for sharing,
cardo0
Great info and excellent link, thanks.
Question, what name sealer do you use on the cap as mentioned above?
Old Mar 15, 2011 | 07:30 PM
cardo0's Avatar
cardo0
Default Many sealers will work.
I used a locktite product i bought from PepBoys years ago but can't recall the designation. I believe anerobic is the term to look for. But really on the main cap u want something fairly thin that won't misalign the cap. I have seen permitex 2 used but it looked way to thick for this. U want something a little runny to fill the micro gaps and move out under bolt torque. I don't think RTV is any good for this but may work.
cardo0
To Rear Main Install ?
