No Spark!!
Old Mar 12, 2011 | 07:55 PM
crj2222's Avatar
crj2222
Default No Spark!!
Repla ed heads, cam, lifters, rods, roller rockers, and added headers and Im trying to fire it up but it seems like there is no spark. Gas is getting to the carb and the engine is turning over but not firing. I swear the distributor is connected correctly. What could I be missing??
Old Mar 13, 2011 | 12:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What year is the car?
Old Mar 13, 2011 | 01:55 PM
kdf1986's Avatar
kdf1986
Recheck your distributor connections. Depending on your year there may be different connections and checks.
I think you probably pulled the distributor out during some of your mods. It looks like you may have missed one of the electrical connections either going to your distributor, or coming out of your distributor.
kdf
Old Mar 13, 2011 | 05:20 PM
ghoastrider1's Avatar
ghoastrider1
did you change points? check coil to see if its getting juice,if not, work back from there. or rather forward.
Old Mar 13, 2011 | 05:35 PM
birdsmith's Avatar
birdsmith
You mentioned that you THINK it's not getting any spark...have you verified this by pulling a plug, grounding it, and cranking the engine to check?
Old Mar 13, 2011 | 08:23 PM
Roughrider's Avatar
Roughrider
By chance is the shielding in place around the distributor? Several years ago my '69 was not getting any spark to the plugs. In my case the coil wire had a pinhole form and the spark was escaping and grounding to the shielding. When I took the shielding lid off the car would start. When I put my hand near the distributor the spark jumped to me and after I recovered from the jolt I had to check my nuts to see if they turned into night lights! A new coil wire fixed the problem.
It's not a common thing for that happen, but something to check. See if your coil wire may be bad.
To No Spark!!
