2 piece timing covers
Old Apr 14, 2002 | 11:10 PM
dogboy's Avatar
dogboy
Default 2 piece timing covers
When I do my cam I was thinking about instaling a 2 piece cover. Which one would be recommended. I heard that the cheap one are prone to leaks. Any truth to this??
Old Apr 15, 2002 | 12:57 PM
robzr's Avatar
robzr
Default Re: 2 piece timing covers (dogboy)
Not sure about the leaks. The 434 I just bought has a Comp Cams 2 piece. It has a short water pump and clearance is tight but it fits. Looks like they changed the bolts out on the water pump as people usually recommend in the forum. Gkull runs a Cloyes two piece, but that one is meant for adjusting cam timing, not changing cams. I think he is happy with it and it also fits with a short pump and different bolts.
Rob
