Speedo cable replacement
Old Mar 13, 2011 | 08:19 PM
psycho dad's Avatar
psycho dad
Default Speedo cable replacement
How hard is it to replace the cable? My biggest concern is threading it through the firewall, there's a lot of stuff in the way behind the dash pad. I'm taking it in to have the instrument lights looked at this week so I may get them to do it if necessary.
Old Mar 13, 2011 | 09:19 PM
jr105's Avatar
jr105
I replaced mine last year, and the hardest part for me was reaching up under the dash and disconnecting it from the speedometer and reconnecting the new one. I have an 81 and I found the easiest way for me to work under there was to remove the drivers seat, a section of the dash below the steering wheel and the heater duct on that side(it just snaps in). Laying on my back on the floor, using a screwdriver, to push the spring clip to release the cable, I pulled it out of the speedo. It pulled out through the grommet in the firewall pretty easily. To get the new cable through the grommet I had to cut a couple of slits so the hole would open enough for the connector. Reconnect by just pushing the cable into the speedometer. I have a 4-speed with no cruise control so I have a 1 piece cable. I ran the cable up from under the car and over the bellhousing before I ran it through the firewall. If you have cruise you have a 2 piece cable.
If you don't mind working up under the dash it's not that hard.
Old Mar 13, 2011 | 10:01 PM
BKarol's Avatar
BKarol
Forum member posted this once to give you an idea what it looks like:
Old Mar 13, 2011 | 10:18 PM
psycho dad's Avatar
psycho dad
I just remembered... I had the speedo out once before. The odometer worked before I took it off, now it doesn't. Did I break something?
Tough call on installing myself, I have a torn rotator cuff. Doesn't bother me much normally, but this sound like the kind of thing that will really aggrevate it.
Old Mar 13, 2011 | 11:33 PM
dgood's Avatar
dgood
My 79 does not have the clip on the back of the speedometer. I have replaced mine a few times, and I think the gear in the transmission is bad because it keeps eating up my speedometer gear. Check the cable, it may have touched a header and melted. Another thing that went bad on mine was the cruise control so I had to get a new cruise control for it also.
Old Mar 16, 2011 | 09:52 PM
psycho dad's Avatar
psycho dad
I got it on. Wasn't that hard. I bought a 1 piece cable from autozone for $11. I had to pull the manifold pipe to get to the bottom end. Thanks for the input everyone
Old Mar 18, 2011 | 12:13 PM
68/70Vette's Avatar
68/70Vette
The original AC Delco cables are still available. About $50.00
Old Apr 5, 2011 | 01:37 PM
jlaw68's Avatar
jlaw68
What was the part number on the cable you used. I believe my cruise control unit is bad and i want to bypass it.
Old Apr 5, 2011 | 05:49 PM
psycho dad's Avatar
psycho dad
Sorry, I didn't save the packaging, don't even rember the brand name.
Autozone has a listing for it though
To Speedo cable replacement
