CLOCK DOSNT WORK
Old Apr 15, 2002 | 07:08 AM
OkeeGuy's Avatar
OkeeGuy
Default CLOCK DOSNT WORK
my clock dosnt work...can they be fixed or should i replace it?
Old Apr 15, 2002 | 07:28 AM
jerryp58's Avatar
jerryp58
Default Re: CLOCK DOSNT WORK (SIGNGUY)
I think you can do either.
I'm pretty sure that some here have opened up their original clock, cleaned & oiled it, and had it work fine.
The previous owner installed a quartz movement in mine (not too difficult from what I've heard) and it's worked great for the almost 8 years I've had the car.
Old Apr 15, 2002 | 09:08 AM
vettfixr's Avatar
vettfixr
You can do either. If you elect to open it up and clean/lubricate it you may or may not get lucky. If it does work somewhere down the road you're going to have to do the same thing again. If you go through the trouble of taking the clock out and opening it up you might as well replace the guts with a quartz movement. I did it to mine and it's kept perfect time for 2 years now. You can also get quartz replacement clocks if you're squeamish about taking yours apart. Most of the major suppliers have the clocks and the conversion kits.
Old Apr 15, 2002 | 10:16 AM
vettedan's Avatar
vettedan
I never owned a C3 with a working clock that keep time. check out Mid America or Eckler's.
[Modified by vettedan, 9:01 AM 4/15/2002]
Old Apr 15, 2002 | 10:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
This trick worked for me. I ran a separate ground for my clock. Old clock has run ever since.
Old Apr 15, 2002 | 10:45 AM
SuperFast80's Avatar
SuperFast80
Default Re: CLOCK DOSNT WORK (Easy Mike)
The title here made me laugh. I didn't know there were C3s with clocks that did work! :lol: :lol: :lol:
Old Apr 15, 2002 | 11:42 AM
verskel's Avatar
verskel
Yeah <sigh> ...mine's not working either ! :(
Old Apr 15, 2002 | 12:18 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: CLOCK DOSNT WORK (verskel)
My clock is dead to.. :cheers: :cool:
Old Apr 15, 2002 | 02:06 PM
Monkeywrench's Avatar
Monkeywrench
Default Re: CLOCK DOSNT WORK (SuperFast80)
How do you think Proteam gets their outrageous prices? They all have working clocks... :lol:
Old Apr 15, 2002 | 02:18 PM
Lasse's Avatar
Lasse
Default Re: CLOCK DOSNT WORK (Monkeywrench)
Welcome to the timeless club.. :lol:
But my clock still works :yesnod:
Old Apr 15, 2002 | 02:28 PM
WESCH's Avatar
WESCH
Hi
I did fix my 68 clock last winter. As already mentioned, it only needed oiling.
Runs a bit fast now, about 10 min per day. Too much oil ?
I also insulated the clock completely from ground and run a direct wire from the battery , this because I disconnect the ground of the battery every time , I shut down the engine. For theft and safety reason.
Works now already for 4 month. Will see if it stays ok.
I agree, lots of work to get it out. Might be worse installing a quartz kit.
Good luck Gunther :seeya
Old Apr 15, 2002 | 03:34 PM
Pogo72's Avatar
Pogo72
Another option: There is a guy that has an ad in most of the Corvette magazines.....'Clocks by Roger'. He is in Jackson, TN. He will take your old clock and either repair it or put in a quartz movement. Don't know the $$. Just my .02.
Al
Old Apr 15, 2002 | 04:12 PM
vettedan's Avatar
vettedan
Default Re: CLOCK DOSNT WORK (Pogo72)
I use the clock in the cd player. I Corvette clock is just for looks.:lol: :lol:
Dan
[Modified by vettedan, 2:13 PM 4/15/2002]
Old Apr 15, 2002 | 04:24 PM
terryrudy's Avatar
terryrudy
Default Re: CLOCK DOSNT WORK (vettedan)
My original C3 clock keeps perfect time. The digital one in my Sony stereo doesn't keep time as good. :)
-terry
Old Apr 15, 2002 | 04:50 PM
page62's Avatar
page62
Default Re: CLOCK DOSNT WORK (terryrudy)
Funny...the clock in my '79 says "Quartz" -- must have gone through a time warp before I bought the car. :smash:
But the readout on my original Delco radio says "IIJI" or something like that -- have the LEDs don't work :crazy:
Old Apr 15, 2002 | 05:53 PM
TonyQT's Avatar
TonyQT
My clock has the right time twice a day. :lol: :lol:
Old Apr 15, 2002 | 06:50 PM
Leos 81's Avatar
Leos 81
I love this subject. Always good for a few laughs!!! :lol:
I'm proud to say that my original clock is still working accurately. Not sure why. Maybe because it gets to rest 6 months out of the year when she goes into winter hibernation. I'm guessing that time will catch up with it. Sorry for that horrible pun.
:jester :lol:
To CLOCK DOSNT WORK
Old Apr 15, 2002 | 07:30 PM
Pete79L82's Avatar
Pete79L82
If you click on the link just under my sig. i have set up instructions for replacing the movemnent in your clock witha quartz movement. It really isn't a bad job to do.
Old Apr 15, 2002 | 07:49 PM
rainman69's Avatar
rainman69
My "Clock" keeps track of the A/F ratio...amazing this "Corvette" technology... :D :lol: :lol: :lol:
Old Apr 15, 2002 | 11:56 PM
Bobbyg75's Avatar
Bobbyg75
Just put in a qaurtz cpnversion from Doc Rebuild and clock works great. Someone earlier said it right: if you're taking the time to remove the clock, either replace it or upgrade with a quartz conversion.
