7040205 Q-jet question
Old Mar 17, 2011 | 01:02 PM
NigelTufnel's Avatar
NigelTufnel
Default 7040205 Q-jet question
I’m looking for a 7040205 quadrajet that is date coded for my car (early July build date), and if I'm paying good money I want an original carb (i.e., not a restamp). Searching around, I found a few on the bag and in one of the auctions someone contacted the seller and made the following statement.
"Its mostly correct right down to the depth of the stamp and the idle backoff but one thing cant be over looked. Its missing the vacuume fitting on the front right side. This connected to the Spark Control System. Its a dead give away. Im sorry to tell you that it is a restamp."
Auction link
Here is a link to a carb that has the port.
carb with port
I then ask someone else who is selling a supposedly original 7040205 about the lack of a vacuum port as described above. This guy tells me that original 7040205’s did not have this port.
So the question is, which is it? Should a 7040205 have this vacuum port? Also, are there easy ways to determine if a carb is a restamp?
Old Mar 17, 2011 | 01:58 PM
Mike Ward's Avatar
Mike Ward
Whether it should have the vacuum port or not I don't know, but the eBay carb is dated 3rd week of November 1969. That's too early for a July built 1970.
Old Mar 17, 2011 | 03:12 PM
NigelTufnel
Yeah I realize that. I was just using the ebay link to show that someone says its a restamp because it doesn't have the vacuum port.
Old Mar 18, 2011 | 12:14 PM
NigelTufnel
Does anyone know the answer?
Old Mar 18, 2011 | 12:33 PM
hwcoop's Avatar
hwcoop
Cliff would probably know!
http://www.cliffshighperformance.com...machinesforum/
Old Mar 18, 2011 | 12:37 PM
NigelTufnel
Thanks! I'll give it a try.
Old Mar 18, 2011 | 07:23 PM
BBCorv70's Avatar
BBCorv70
If you need a picture, follow this thread down to the posting from Spinadog. A photo of the right side of his carb. Bottom right side of the photo shows a tube which is capped off. Probably the tube you are asking about.
http://forums.corvetteforum.com/c3-g...-70-454-a.html
Old Mar 18, 2011 | 07:47 PM
NigelTufnel
Thanks! I should of thought about asking for a pic of an original carb. Unfortunately, none of those pics show the port I'm referring to.
Looking at the front face of the carb, the port would be on the right side of the front face. If you click on "supersize" for the first pic in the teamchevelle link in my original post, you can clearly see the port. If anyone could post a pic of a 7040205 that is orignal to their car, I would appreciate it!
Old Mar 18, 2011 | 10:46 PM
qtlow's Avatar
qtlow
I'll admit I'm not expert but I do know there are a lot of people out there that claim to be and those people usually don't have a clue what they're talking about. If you go back to the auction site again some posted another reply correcting the previous one. I don't think original 205's are suppose to have that port. As far as I know the only carburetors that should have that port are the one that came factory with California emissions. And if it did it would be a number other than 7040205. It would read something like 7040???
Old Mar 18, 2011 | 11:11 PM
Dave J's Avatar
Dave J
If you have access to the 1970 chassis overhaul manual I believe you'll find your answer. The port you are referring is called the canister purge signal tube (RPO NA9). This is also known as California emissions. You can find the exact reference on page #6M-26, figure Q1. Also in the specifications pages (page 18) you will find the carb part #'s for all 1970 cars and trucks. Without NA9 option, the carb should be 7040205, and with NA9 it would be 7040505.
I will admit I don't have a lot of personal experience with the BB carbs, but this dovetails exactly the way the L46 (350/350) small block cars are equipped.
If you do another search on ebay for 7040205 and completed listings, you will find several other carbs to reference.
Good luck.............
To 7040205 Q-jet question
