door gap adjust?
Old Mar 18, 2011 | 08:26 AM
briaineo's Avatar
briaineo
Default door gap adjust?
Hi
My 69's passenger door seems to be always ajar slightly.
I've adjusted the door striker as far as it will go inwards but there is still a slight gap.
Is there any other adjustment that can be made?
Old Mar 18, 2011 | 08:56 AM
U17's Avatar
U17
Are your body / frame mounts good? If they are deformed it can twist your body ...
Old Mar 18, 2011 | 09:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There are shims on the hinges. Removing shims will bring the door in. Mark all the shim stacks before you start making changes.
Have you replaced the door main weatherstrips? New door mains can sometimes make the door stand out until they take a set.
Old Mar 18, 2011 | 01:44 PM
ripforrey's Avatar
ripforrey
Is it out at striker and in at hindge? Then it maybe the door shims.
To door gap adjust?
