Need Help getting my engine to run right.
)Anyways, It was leaking out of the front of the intake manifold, so i decided to stop the leak with new gaskets etc.
It ran great before, and after I got done installing the new gaskets, it now does not want to idle when cold. (But no leaks... one step forward one step back...)
When I first start the car, it takes waaay to much gas to get the darn thing to idle. Once I get it to idle, if I put it into gear, it will die unless I give it a large amount of pedal.
Once I get the car moving, it likes to bog down, almost back firing out of the carb. I have to drive it at least a half mile babying the throttle for it to stop this behavior. It dosnt matter if its warn or cold outside, it will still do all of this.
The wierd part is once I get the engine about 150 degrees, it runs fine, just like it used to.
We have already set the timing etc. What do you guys think that it could be? Vacuum leak somewhere? Idle not set correctly?
http://www.secondchancegarage.com/public/186.cfm
1. Massive vacuum leak
while it is running spray carb cleaner around the manifold edges and any sealing points (carb base ect). That stuff is flamable so be careful. If you find the problem the idle will jump up.
2. Distributor off a few teeth or 180 degrees off.
good luck!
Sounds like an improperly adjusted choke, or a vacuum leak, or both.
I have a vacuum gauge, a timing light, and a rudimentary knowledge of carburetors. I will probably be home doing some work on my vette tomorrow, if you want to bring some beer over I would be glad to take a look at it with you.
PM me for address.
Ben, I am also having some issues, with my carb and idleing. I think I might possibly have a vacuum leak. I did try the carb cleaner spray test, but realized that the over spray or any miniscule amount that finds its way to the carb will surge the idle. Especially on a windy day. I found it to be a difficult method.
P.S. I normally use just little, tiny puffs of that stuff pointed right at the area I want to check.
Im hoping soon ill be able to talk to Mike (mds3013) and we can all have it figured out.
PM me for address.
gotta love the forum
