1980 Corvette engine light
Were did you get this information? My Corvette Shop Manual shows code 23 as an "Open or Grounded Mixture Control (M/C) Soleniod Circuit", not a Manifold Air Temperature Sensor. I took this from the 1981 Corvette Shop Manual, but I think the codes for all 80-82 GM cars to be the same.
[/IMG]
Your check engine light will remain lit as long as there is a problem in the system. If the problem is intermitant, the light will stay on for a few seconds after start up, and then go out. Even though the light has gone out, the ECM will store the fault code. These code(s) will only be cleared after 50 engine starts (without the problem recurring), or if the battery is disconnected.
GM first used the Computer Command Control (CCC) system on 1980 California emission cars, including the 305 powered 1980 Corvette. 1981 was the first Federal emission use of the GM CCC system and the E4ME Q-Jet (though I think there was some limited use of the CCC in certain 1979 GM vehicles too).
Go throught the troublesooting proceedures shown above. If the issue is the MC Solenoid, they are still available and are fairly easy to replace. The ECM can be bought on Ebay. But it may be something as simple as a loose ground or corroded connector.
The computer controls the Carb AND the distributer timing advance. If you only change the carb, the timing advance will still be wrong -- driveability will suffer.
The E4ME carb is pretty easy to work on, not much more than a stock Q Jet. It does require a few special tools / gauges to set the mixture control solenoid though. You can usually get these off of ebay for about $20.
Heck if you want, you can send me the carb and I will put a kit into it. You pay shipping both ways and the kit plus float. Takes me about an hour to rebuild and do the settings since I have done this several times.
Send me a PM if interested.
