So I figured while I am working on the hydroboost and O ring calipers I might as well do something about the 38 year old wheel bearings. New AC Delco bearings and races ready to go in but one quick question. Should I clean the roller bearings first before I pack them. brake cleaner? simple green, thanks
On new ones? Why would you want to do that, assuming they are packaged and haven't been dropped in the dirt?
If you absolutely MUST clean your new bearings (to get that ten-year old scuzz off of them from the packaging) I would spray them down real good with Simple Green in your CLEAN hands, work it in real good and the rinse them thoroughly with water, blow them dry with compressed air and spray them with WD40 before packing them with grease. The main thing is to get them absolutely clean without introducing any grit or debris, and then getting ALL the rinse water out of there...
New bearings are already packed in preservative grease and can be installed "as is". Unless they have been stored in a hot environment and the grease has leaked out, there's no real need. Now, if you prefer to put modern synthetic grease into new bearings...just because you want to...then you need to use a volatile cleaner to disolve the existing grease, then repack them with synthetic stuff.
Yeah the new timken bearings i have in an AC Delco box are sealed in a sealed bag and dry as bone no grease to leak out. Just the rust preventative film.
