Antifreeze leak....
Old Mar 21, 2011 | 12:46 AM
jtramont's Avatar
jtramont
Default Antifreeze leak....
Guys, I pulled my headers and had antifreeze running from one of the bolt holes (drivers side closest to the firewall). I pulled the cylinder head (World) and valve and can't see where the crack is. The good news is that the car was running fine but obviously there is an issue...
Any ideas on how to resolve it?
Old Mar 21, 2011 | 09:52 AM
Roughrider's Avatar
Roughrider
To be honest, I'm not sure Chevy engines are like this, but in some designs (Mopar big blocks come to mind), the exhaust manifold bolts thread into the coolant passages. In that case, it would be normal for coolant to run out when removing a bolt.
If a Chevy engine is designed like that, you're having no problem. If it's not designed like that...well...you do have a problem.
Hopefully, someone else here will give you the answer you need.
Old Mar 21, 2011 | 10:13 AM
7T1vette's Avatar
7T1vette
Just put a bit of black RTV sealant on the last few threads of the bolt before you install it. That should seal any leakage via the threads....unless the head is 'cracked'. Are the bolts the same length as stock bolts?
To Antifreeze leak....
