*Question About The CS-144 Alternator*
)I do know that I went through two "Part Store" CS144s and neither would keep up with all of my electrical draw at idle. SO I had Alternatorparts.com build me one of their CS144HD with AC Delco parts and the good rectifier/regulator. Now I have no less then 13.3v at 800rpm idle at FULL ELECTRICAL LOAD....(headlights, hi beams, AC on HIGH, Lincoln Mark 8 fan running, stereo w/ AMP blasting, foot on the brakes(brake lights).... Been on for a couple thousand miles now, no problems at all.... Around $205 shipped.
Do you run all your high amp accesories through relays directly off the alternator or do you run them through the fuse box? Stock wiring or did you rewire the fusible links?
*My lincoln MK8 fan gets power off of the alternator stud, runs through a 75 amp bosch relay and a 50 amp circuit breaker, all with 8 ga wiring.
*My stereo amp goes directly to the battery(pos/neg) with 4 ga wire and a big a$$ fuse...(I don't recall the amperage of the fuse)
*My stereo head unit is getting 12V switched power from the factory radio wires and it gets 12V constant power from the factory cigarette lighter orange wire.
*My MSD 6AL is getting power from the starter lug and is triggered on with a 12v ign slot on the fuse box. I believe it was 10 ga wiring that came with the MSD harness. It has an inline fuse. Ground wire runs to the frame.
*My Vintage air gets 12v power and ground directly from the battery but it has its own relays/ECU on it.
*My CHARGE wire from the alternator stud is 8 ga and runs to a 12 ga fusible link wire at the starter. I also run an additional 8 ga charge wire with 12 ga fusible link all the way back to the battery.
Everything is else stock wiring and relays. Everything works on my car, even the door ajar lights and odd ball indicator lights (seat belt, hi beam etc etc)..
Here is a few pics of the wiring/relays etc...
The only thing I don't like about them is they don't like high RPM, mine blew at 7000RPM at the crank and IIRC the guy that fixed it said the alternator turned at least twice as fast as the motor so my aleternator blew at 14,000 RPM's
