AFR Heads and Hooker headers
Old Mar 22, 2011 | 03:58 PM
c3corvette77's Avatar
c3corvette77
Default AFR Heads and Hooker headers
Does anyone know if there are any fit problems with the Hooker Competition headers and the AFR cylinder heads? Do you run into either a problem bolting the header on or any clearance issues with the frame from the raised exhaust ports? I tried doing a search but there are way to many returns to find anything....
Old Mar 22, 2011 | 06:39 PM
vette427-sbc's Avatar
vette427-sbc
AFR 180's and Hooker sidepipes here... No problems at all. I can get to all spark plugs (angle plug) easy, and the wires dont touch the headers.
Old Mar 22, 2011 | 08:44 PM
C3 Stroker's Avatar
C3 Stroker
I have Hooker Super Super Comps and AFR 210 Eliminator heads (angle plugs)....no problems at all.....easy access to plugs, frame clearance is good. The raised ports (.250") are not an issue.....remember that heads angle out, so it's not really a straight up vertical rise; maybe an 1/8" at most.
Bottom pics...
Front view
Old Mar 22, 2011 | 11:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Hooker, they will fit some angle plug while not fitting other heads. I believe they say the don't fit angle plug heads in the ad.
If you want a SS set with 1 7/8" primary pipes, these are the best set of headers I have ever had my hands on and they sell for a little more than the painted Hooker Super Comps. The company is a Forum sponsor Custom Image :thumbs:
Just a note to say they fit my AFR 227 angle plug head so there is a good chance they will fit the 210's
I am putting them on, drive to the same shop that I used previously
and I am looking for the magic 500RWHP all motor. It will happen soon but she's still in hibernation. :toetap:
Ground Clearance
*This goes on all my posts: Please report back to those who helped you the final outcome of your initial post :cheers:
Old Mar 23, 2011 | 08:43 AM
Phil Zell's Avatar
Phil Zell
AFR 195's, here with angle plugs, no problems with Hooker Super Comp side pipes
Old Mar 23, 2011 | 09:07 AM
c3corvette77
I currently have super comp ceramic coated and sportsman 2 heads. Planning a change to AFR 195s and more cam. Wanted to make sure my headers would still cut it. Sounds like they will. Thanks guys.
Old Mar 23, 2011 | 09:09 AM
c3corvette77
Oh, one more thing. You guys running angle plug heads, are you using short plugs to gain extra clearance or do standard plugs get it done?
Old Mar 23, 2011 | 11:23 AM
vette427-sbc
Standard length Champions
Old Mar 23, 2011 | 09:19 PM
C3 Stroker's Avatar
C3 Stroker
Previous to the current AFR 210s, I had AFR 195s with these same headers.....they will fit. I use standard size Delco plugs. The tightest area is the #6 plug, but it accessible.
To AFR Heads and Hooker headers
