Coolant in Engine.....Help
Old Mar 22, 2011 | 10:05 PM
DO2G's Avatar
DO2G
Default Coolant in Engine.....Help
I noticed a small oil leak in the back if my intake manifold. I recently changed my heads and probably didn't have a big enough bead of RTV.
I took the inatke off, but didn't think to drain the coolant first, so lots of coolant drained into the engine.
Should I just change the oil and clean the intake valley? Is there aything else I need to do?
Old Mar 22, 2011 | 10:47 PM
Roughrider's Avatar
Roughrider
I would change the oil and filter and add some engine flush...run it up and then change the oil and filter again. Engine bearings do not like ethylene glycol at all. Get that glycol flushed outta there!
Old Mar 23, 2011 | 06:12 AM
DO2G's Avatar
DO2G
thank you
Old Mar 23, 2011 | 06:57 AM
L88Plus's Avatar
L88Plus
I'd stay away from engine flush, it can break stuff loose that can find it's way into tiny oil passages. Tranny fluid is high detergent and works better, IMHO, don't use more than a quart, though.
I've had this happen a few times, I use naphtha or paint thinner to wash out the lifter valley. Let it set overnight, the antifreeze will end up at the bottom of the pan and will all drain out with the oil. A few drops of antifreeze aren't going to hurt anything, do a short change if it makes you feel better.
Now a bunch of antifreeze in the oil of a running engine, that's another story altogether. Ask anyone who's had a vortec engine develop their common intake gasket problem and lost bearings because of it.
Old Mar 23, 2011 | 09:37 AM
wcsinx's Avatar
wcsinx
Done that plenty of times
Just change the oil, and you'll be fine. Flush out the intake with paint thinner or diesel fuel like L88Plus said if you want some piece of mind.
To Coolant in Engine.....Help
