Oil Viscosity
Old Mar 23, 2011 | 10:46 AM
ElCameeeno's Avatar
ElCameeeno
Default Oil Viscosity
Is 20w-50W oil to thick for a stock L48 in a Southern (i.e. Texas) climate?
This is not a ZDDP question, just a viscosity question. I have the oil, but am hesitant to use it until I get some feedback on way or the other.
Thanks!
Old Mar 23, 2011 | 11:18 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Its not optimum, but its not going to ever cause a problem that you will notice.
Old Mar 23, 2011 | 11:36 AM
Mike Ward's Avatar
Mike Ward
What does the owners manual say?
Old Mar 23, 2011 | 04:19 PM
LB66383's Avatar
LB66383
I use it in all of my SBCs.
Old Mar 23, 2011 | 06:35 PM
jb78L-82's Avatar
jb78L-82
20W-50 is specifically recommended in my 78 owners manual for temperatures down to 32 degrees! In a warm climate like in Texas it would be very suitable! I use a 15w-50 in my 78 stock L-82 and have for years in spring, fall, summer and very occasionally in the winter in The Northeast.
Old Mar 23, 2011 | 06:46 PM
msandym's Avatar
msandym
Default oil v
In my rebuilt engine , it seems to work the best . I seem to get oil leaks from passenger rear side with thinner oil .
Old Mar 23, 2011 | 09:13 PM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Check the owners manual as Mike Ward says
Here at the forum the guys will run a wide range of opinions.
Depends on year engine and climate.
I have a 78 L82, live in Northwest Indiana. Car is stored 5 to 6 months. I run 10w30 according to the manual. I WON'T GET INTO ZDDP
Old Mar 23, 2011 | 09:23 PM
Mike Ward's Avatar
Mike Ward
good plan!
Old Mar 23, 2011 | 10:26 PM
valve cover gasket
Old Mar 23, 2011 | 10:31 PM
Originally Posted by Mike Ward
good plan!
ZDDP
After that comment I decided to add the truth
Use conventional oil for ZDDP. That was what we had when these cars were built. Want best protection use Valvoline SynPower.
Period
This is according to independent studies backed by GM and Valvoline. Don't use Mobil 1 in an old engine. If engine is new use Mobil 1 if you like. Or if your owners manual calls for it. Better choice still Valvoline. The oldest oil in US History
Old Mar 23, 2011 | 11:22 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
ZDDP
Period
Valvoline SynPower has under 800PPM zinc (ZDDP)
20W-50 oil does not provide as good of cold start protection. By cold start I am not talking about it being cold outside. Check and see how long it takes for your oil pressure guage to jump up from 0 when starting after sitting for a few days. This time lapse is where 90% of engine wear occors. The longer this takes the more wear and that wear increases drastically as more time passes. Thicker oils take longer. The thicker oil also puts additional strain on the distributor/cam gears that drive the oil pump. They also reduce horsepower having to push the crank through thicker oil every RPM this causes additional loading on the main bearings and reduces fuel mileage. Why use them? Try the same time test with a good full synthetic 10W-40. The time it takes for the oil pressure guage to jump in a cold start will be less than half the time. That is way less than half the wear.
Old Mar 24, 2011 | 12:09 AM
Steve439's Avatar
Steve439
Also, I am shocked that a test paid for by Valvoline determined Valvoline is the best oil.
Old Mar 24, 2011 | 12:31 AM
Paid by Valvoline, I never claimed that you must have bad eyes. Also Syn Power has 1000 PPM ZDDP acording to Valvoline. Valvoline is the only oil who has the 3000,000 engine guarantee. End of argument. Some people here have to argue. get your facts straight
Old Mar 24, 2011 | 12:52 AM
Mike Ward's Avatar
Mike Ward
Here we go..............
Old Mar 24, 2011 | 08:55 AM
ElCameeeno's Avatar
ElCameeeno
I got the info I needed from your responses. Thanks to all for the advice.
Time to let this thread go....
To Oil Viscosity
