383 stroker harmonic balancer issue
Old Mar 23, 2011 | 11:43 AM
69/03vette's Avatar
69/03vette
Default 383 stroker harmonic balancer issue
Why is the harmonic balancer to short? Let me explain new 383 stroker using 400 SB w/8" 400 harmonic balancer. When you install the balancer it won't allow the crank pulleys to align with the other pulleys. I know Morroso and Sumitt have spacer kits for this issue, but the timming tab actually extends past the outer edge of the balancer making it almost imposible to set the timming. What is the fix? Can not find a longer balancer and I don't think I want to space the balancer out from the engine.
Old Mar 23, 2011 | 12:22 PM
gkull's Avatar
gkull
I'm not in front of your car and can't tell you for certain. But you do understand that you have an Externally balanced motor? This new damper has to be made for external balanced and it would have to duplicate your original balanced set with the flex or flywheel
I think that it is possible that you have a thinner internal balanced damper
Old Mar 23, 2011 | 12:44 PM
69/03vette's Avatar
69/03vette
No this is an externally balance damper for a 400. The one the engine supplier recommended. Funny thing is they say this has never been an issue.
Old Mar 23, 2011 | 01:55 PM
gkull's Avatar
gkull
I have not fully pressed dampers on before to line up the pulleys. but I'm talk just a 1/4 inch or so. All you have to have is enough of the damper shaft seal against the timing cover seal. So you could pull it out.
This is new. So is it possible that a 400 uses a different width crank pulley?
Can you post a picture? The timing tab doesn't make sence
Old Mar 23, 2011 | 02:49 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Pulleys are slightly different for our C3's compared to an ordinary setup the gaps between the pulley grooves is different, so when you buy a pulley setup for a C3 you have to make sure it is for a C3
As for your timing tab I had the same problem and used a grinder to cut the top off the tab right at the 0 degree mark
*This goes on all my posts: Please report back to those who helped you the final outcome of your initial post
Old Mar 24, 2011 | 09:35 AM
69/03vette's Avatar
69/03vette
This is what I have. Not real clear but you can see what I'm talking about. From what I can find out so far there is only one length for the 400 SB balancer.
Old Mar 24, 2011 | 10:00 PM
jackson's Avatar
jackson
damper looks like asian piece from pro products.
Just get the moroso crank pulley spacer kit and use new grade 5 or better bolts; it'll be fine.
To 383 stroker harmonic balancer issue
