My Differential
Old Mar 23, 2011 | 10:24 PM
Dream Bikes's Avatar
Dream Bikes
Default My Differential
Here are some pics after a first inspection...
It looks good, do you agree??
It's a Posi 3.08, side play 0.030" right and 0.053" left
I'm doing a frame-off restoration, my car is a 69" with TH400 and a more than 400 hp 383.
I'm quite confused about what to do with it...only a cosmetic refresh, or a total rebuild swapping to a 3.54 or 3.73 ???
I will use the car especially for urban cruising, track day and sometimes for drag races, so few highway mileage.
What do you think about it?
Old Mar 23, 2011 | 10:56 PM
joewill's Avatar
joewill
nothing much one can see here regarding bearing wear and how well the teeth mesh..
how did it sound during accelleration and decelleration? any whine-ing or growling?
can't tell about the clutch pack either..
the yokes look great..
get you a heavy duty rear end cover and put caps intead of those straps to hold your half shafts on..
Old Mar 24, 2011 | 08:23 AM
BigE's Avatar
BigE
Its hard to tell, but in the fourth pic it looks like there is a small hairline crack in the posi case in the lower right corner of the window. Could you get a closer picture? Hopefully that is not what I am seeing because if it is you might want to replace the posi housing.
Old Mar 24, 2011 | 10:51 AM
Dream Bikes
I will check the case thanks!
Old Mar 24, 2011 | 09:05 PM
Dream Bikes
What do you think shall I go with a 3.54 or with a 3.73 ???
I remember you that my car is a 69" with TH400 and a more than 400 hp 383 engine.
To My Differential
