C3 start relay issue
Old Mar 24, 2011 | 06:31 PM
bisomjoe's Avatar
bisomjoe
4th Gear
Default C3 start relay issue
I have a '79 L48 that I've owned since '86. Seems I have been blowing relay on right side fire wall. Not good, won't start, but will with remote start switch. after roll back tow bill I now carry at least 2 in glove box. I un hooked ac compressor wire no help replaced heater fan switch, no help anyone else having this problem or am I just lucky Thanks bisomjoe
Old Mar 25, 2011 | 10:13 AM
bashcraft's Avatar
bashcraft
I'm not sure what relay you're talking about. Mine doesn't have one, but relays usually don't blow out. Are you talking about a fuse?
Old Mar 25, 2011 | 04:10 PM
bisomjoe's Avatar
bisomjoe
4th Gear
There is a metalic relay in the center of the right half of the firewall mounted high. top wire plug is blue brown red (heavy wire) bottom plug is black & orange lite wire. Maby you could have a talk with the Chineese relays about blowing. This has been an issue for quite some time, seems to be getting more frequent. I do know that if I replace the relay it will start and operate for a while, If I put the old relay back in no start. In indiana we refer that to a blown relay. Thankls Joe
Old Mar 25, 2011 | 05:41 PM
...Roger...'s Avatar
...Roger...
Sounds as if your describing the high "blown" relay , it shouldn't effect the starting of your engine.
To C3 start relay issue
