69 Mechanical to Electric Tach Conversion
Old Mar 25, 2011 | 09:43 AM
KanuckZ06's Avatar
KanuckZ06
Default 69 Mechanical to Electric Tach Conversion
Has anyone have a list of parts required to convert a mechanical tach to electric?
I've been thinking of installing a EFI system and need to convert the tach.
I have used the search function and haven't found what I was looking for.
Thanks as always everyone!
Old Mar 25, 2011 | 10:15 AM
mrvette's Avatar
mrvette
A stock tach from 75-77 vette will bolt in just fine, slight print variation but not so shabby.....
the wiring is obvious.....ground, +12 and tach input through a tach filter....which is easy to make if you can solder a wire, if not, I think someone tooled up to make them OEM style...
Old Mar 25, 2011 | 10:23 AM
Mike Ward's Avatar
Mike Ward
The lettering on your '69 gauge is greenish white, the electronic tachs as described have white lettering.
Since converting to HEI will not give you any performance boost, why bother? If you're tired of playing with points, convert your existing dist. to one of the electronic points replacement thingys and be done with it.
Old Mar 25, 2011 | 02:45 PM
Garys 68's Avatar
Garys 68
The 75-77 tach is probably easiest, but they were expensive when I did my LS swap. I had an Isspro tach on my shelf that had the same sweep and even the same faceplate screw hole locations as my 68 tach. I pulled the guts out of the Isspro, swapped the 68 face on it and mounted it in the dash.
Old Dec 14, 2011 | 04:18 PM
brando1118's Avatar
brando1118
Gary 68,
What was the model number of the Isspro tach that you used for your tach swap? I need to do this to my 70.
Thank you.
-B
To 69 Mechanical to Electric Tach Conversion
