Driveshaft Balancing Question
Old Mar 27, 2011 | 12:36 AM
spdrcr29's Avatar
spdrcr29
Default Driveshaft Balancing Question
Hey guys I recently sent my driveshaft out to be balanced. Before sending it to them, I beadblasted the entire driveshaft and purchased a new front transmission yoke. When they balanced it, they attached the front yoke and balanced the yoke and driveshaft together as one unit. My question is now that I have the driveshaft back, I was wanting to paint it, but forgot to ask the guys if removing the u-joints so I can paint the shaft will affect the balancing. I figure that as long as I mark Exactly how everything came apart and put it all back together the same way, I will be in good shape?? OR Should I just leave it alone and figure out how to paint around the u-joints without removing them?? Please let me know your thoughts. Thanks!
Old Mar 27, 2011 | 01:32 AM
7T1vette's Avatar
7T1vette
Just mark it so you can realign it the same way, and paint it any color you like.
Old Mar 27, 2011 | 08:22 AM
'75's Avatar
'75
Or just paint the u-joints and all.
Old Mar 27, 2011 | 09:54 AM
Chromie69's Avatar
Chromie69
It wont be a problem at all taking them apart and putting it back together..use a punch to make a mark and not a marker or something that can be erased..might want to use an F for front and a B for back so that doesnt get mixed up..being they were just put in they should pop apart real easy..
Old Mar 27, 2011 | 10:35 AM
fugawi's Avatar
fugawi
Old Mar 27, 2011 | 11:31 AM
njfl's Avatar
njfl
Spend an hour or so masking the U-joints. 2 inch wide blue painters tape works nicely. Remove the Retaining clips and mask off with a simple circle. No need to take it apart. Just take your time.
Old Mar 27, 2011 | 06:38 PM
spdrcr29's Avatar
spdrcr29
Thanks your all of your feedback guys! I had plans to work on the driveshaft today, but it was too cold in the garage to work....so I sat on the couch and pigged out on Doritos instead!! Oh well, maybe I'll work on it next weekend!
Old Mar 27, 2011 | 06:46 PM
Chromie69's Avatar
Chromie69
I like Doritos..
To Driveshaft Balancing Question
