Driveshaft Questions?
Old Mar 27, 2011 | 11:24 AM
Dante7's Avatar
Dante7
Default Driveshaft Questions?
1. How do you measure the length of a driveshaft?
2. How far should the slip yoke stick out of the transmission?
3. How far should the slip yoke go into the back of a M22?
4. How do you tell if a universal joint is bad?
Thankyou in adavance
Old Mar 28, 2011 | 09:19 AM
gkull's Avatar
gkull
1 center to center on your shaft u-joints
2 Vette rears are solid mounted so you don't have to allow or in and out movement. So your the yoke leave about 3/4 to 1 1/4inch out to help space for u-joint replacement ease
2 -3 are the same. You bottom out and then pull it back
4. Any slop or movement. They are cheap and you just replace them while things are apart.
I run a shorter shaft with 1320 spicer u-j's with my tko 600
