pulling to the left...
Old Mar 27, 2011 | 05:32 PM
Fscott82's Avatar
Fscott82
6th Gear
Default pulling to the left...
My 82 pulls to the left when I brake. I have replaced the front calipers and have bled, bled, bled, bled......still pulls. Sometimes its worse than others.
Would the rear calipers be affecting the fronts??? Any thoughts on this will be appreciated.
Old Mar 27, 2011 | 07:44 PM
sly vette's Avatar
sly vette
See if the R/F caliper is working properly. Specifically check to see that it is releasing. Check by trying to spin the R/F tire by hand and then compare it to the L/F.
Old Mar 27, 2011 | 07:49 PM
'75's Avatar
'75
Could be a colapsed hose to the RF caliper, so it's not helping and the left is doing all the work.
Old Mar 27, 2011 | 08:18 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My 82 does the same thing. I'm going to replace all 4 lines with SS lines. I think the rubber is old and collapsing. I may just go for the whole calipers, rotors, lines, and pads swap this fall.
Old Mar 27, 2011 | 08:33 PM
scott2173's Avatar
scott2173
mine did the same thing after replaceing the calipers it was the rubber brake lines replace them both and if they havent been replaced before be ready to replace the steel lines back to the propotioning block
Old Mar 27, 2011 | 11:15 PM
81pilot's Avatar
81pilot
OK... I just rebuilt my steering control valve, after which I balanced it, but didn't get it quite right, when I braked it pulled hard left. I did a little more adjustment and it tracks straight when I brake. I am not saying it is the steering valve, but it was in my case.
To pulling to the left...
