TRW Rear Spring
Old Apr 16, 2002 | 02:26 PM
Koz
Guest
Posts: n/a
Default TRW Rear Spring
What did you guys pay for your TRW spring? I have an option to buy one for $183 and wanted to know if it's a good deal.. It's a 330lbs spring.. I need to know ASAP..! Thanks!
Old Apr 16, 2002 | 02:29 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: TRW Rear Spring (Koz)
I don't remember -- but you can check with Zip, Vette Brakes and Products or Muskegon brake. They all sell the same style.
I love my mono spring -- just remember to get the correct shocks for it or you will not like the results.
Can you say "rebound" boys and girls ?
Also, see the Tech Tip I wrote on swapping a steel spring for a mono in the C3 tech section above. It should help you a lot.
Old Apr 16, 2002 | 02:48 PM
Split Sixty Three's Avatar
Split Sixty Three
If it's new right out of the box then I'd say go for it!! I paid about $320 for a TRW 330 lbs. rate spring a couple of years back. Don't think you'll run across one much cheaper unless u luck out at a swap meet or someone else has one they just want to unload for quick $'s,.. :chevy Save the Wave!!! :cheers:
Old Apr 16, 2002 | 03:07 PM
flynhi's Avatar
flynhi
That's a very good price. Combine it with Bilstein Sport shocks from VB and you will have a ride that you will love.
I also suggest using VB's long spring bolts to lower the rear until the half shafts are level with the ground - but no further.
Old Apr 16, 2002 | 03:48 PM
Koz
Guest
Posts: n/a
Default Re: TRW Rear Spring (BSeery)
BSeary,
I read your tech tips.. even printed them out for the "reading room".. :D
What shocks did you go with? Did you also use the longer end link bolts?
BTW - how's the ZZ4 doing?
What length end link bolts will I need? 8", 10".. or are they adjustable?
[Modified by Koz, 2:54 PM 4/16/2002]
Old Apr 16, 2002 | 04:50 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
I used the bolts that came with the kit. I do need longer bolts now to lower it further, but only because I have lowered the front soo much.
The ZZ4 is running great, but I really need to get the dual exhaust installed soon.
To TRW Rear Spring
