10 leaf rear spring?
Old Mar 30, 2011 | 03:20 PM
billsfan's Avatar
billsfan
Default 10 leaf rear spring?
I have what appears to be a 10 leaf, 2 1/2" wide rear spring on my '76. It rides like a truck, no bounce at all in the rear (skip the "junk in the trunk" jokes) ha-ha. With 8" bolts, it measures 29" to the rear fender opening. It seems that when the PO switched to a later spring, he must have added a leaf for some reason. If I just want to remove a leaf, do I remove the top one, which is only about 8" long?? I know that switching to a fiberglass spring might help the ride, but I've read lots of ride height issues with glass springs. Any ideas?
Old Mar 30, 2011 | 03:41 PM
gkull's Avatar
gkull
I added a leaf to my 9 leaf years ago. the added leaf is generally the second one from the bottom. If it was rebanded or rivited your kinded of screwed. Mine was also rearched.
I've had good luck with rear mono springs with the stock length bolts. The low rider look just takes longer bolts
Old Mar 30, 2011 | 03:45 PM
bashcraft's Avatar
bashcraft
Mine had an extra leaf in it when I bought it. I just took it out. It was the second from the bottom.
LB66383's Avatar
LB66383
Removing a leaf, especially that little one on the top, isn't going to make any difference in the ride comfort. You should investigate the various springs that are out there, both metal and plastic, and pick a spring rate that will give you the comfort you want. There's lots of experience on this forum with rear spring rates. And look into shocks as well, they have a lot to do with ride comfort. Don't sweat the ride height, that can be adjusted with the bolts.
Old Mar 30, 2011 | 03:50 PM
billsfan's Avatar
billsfan
Thanks guys. Since I don't know what the PO did to this spring, it makes more sense to find a new medium rate glass spring.
Old Mar 30, 2011 | 04:49 PM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
63 - 82 had 7 or 9 leaf spring. Everything I see 78 had 9. My 78 originally had 7. The vendors said it should have had 9. The spring was week and so replaced with 9.
Old Mar 31, 2011 | 02:00 AM
mauiwilly's Avatar
mauiwilly
I had the 7 leaf on my 81....replaced with the TRW composite and sensatrac shocks....what a difference in the ride and handling
To 10 leaf rear spring?
