tunnel ram
Old Mar 31, 2011 | 12:11 AM
vettlag's Avatar
vettlag
Default tunnel ram
any take on a 383 with tunnel ram duel 390's or 450's and thumper cam
Old Mar 31, 2011 | 07:35 AM
bashcraft's Avatar
bashcraft
Back in the early 80's I had a Wieand tunnel ram with 2-450's and a GM off road mechanical cam in a '70 LT-1 with 4.56 gears. It didn't start making any power til about 3500-4000 rpm, but once it hit the power band you had better been holding on. It was still pulling at 7800 rpm. It ran 112 mph in the quarter on junk bias ply street tires.
Old Mar 31, 2011 | 09:39 AM
gkull's Avatar
gkull
This kind of question is usually a waste of time because the person asking doesn't ever buy the (Tunnel Ram) or what ever else they dreamed up.
It is also hard to gauge a persons mechanical skills and the amount of disposible money over the faceless internet.
tunnel rams are not for the clueless unless they have a personnal mechanic.
If you do some reseach and tell me some specifics about the motor, which thumper cam, which tunnel ram I might to be able to give some advice because I have owned, driven, and worked on them
Old Mar 31, 2011 | 12:22 PM
Imo Apita's Avatar
Imo Apita
A couple of years ago they did a write up in HotRod magazine about 4 or 5 tunnelram setups for the SBC. Some of them were very streetable, mind you not cheap.
Some made less power then a properly setup single 4 barrel setup. So mainly show no go
Old Mar 31, 2011 | 02:06 PM
hugie82's Avatar
hugie82
We did 390's on a sbc400 and it was streetable but with todays fancy heads it might be worth the chance to go with the bigger carbs.
Old Mar 31, 2011 | 04:52 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Years ago, after thinking it thru I sold the only tunnel ram I ever owned (BB TR2X) at a Super Chevy swap meet before ever installing it. Didn't want an engine good for only one thing on a street machine.
Today, IMCO off-the-shelf tunnel rams make little sense. If building a dedicated drag car, have a proper sheetmetal intake built specifically for the engine in question. The people that do that for a living will know far more about designing them that you'll learn on the interweb.
Old Mar 31, 2011 | 05:15 PM
bluzman2004's Avatar
bluzman2004
I have a Weiand tunnel ram with 2 holley 450's and linkage for sale. the choke plates have been milled already. The tunnel ram was polished at one time, but could use some Mother's polish again. This was on my small block last year and ran in the 9's at the track and driven home. I've ran these on everything from 350's to my current 434. I've just upgraded to the Victor Ram now and don't need this one anymore. PM me if interested. $300 plus shipping.
Old Apr 1, 2011 | 08:47 AM
Nobody.'s Avatar
Nobody.
I'm partial to tunnel-rams myself. But this is a drag-only car:
Old Sep 24, 2011 | 07:28 PM
FastEddy's Avatar
FastEddy
355ci with AFR 195's, weiand tunnel ram with 450's (kit from summit), 3:55 gears and a 5spd. After some simple tuning, (and a little more to go), the setup runs great...no hesitation, no fouling plugs, idles fine, awesome response. When cruising, seems to be about the same gas mileage as my 750 - maybe since both setups used a total of two 50cc accel pumps. Only reason to be affraid of a tunnel ram is the hole in the hood
Tunnel rams only for drag racing? Nope..... See videos, one at idle, and one running down the road....
http://www.youtube.com/watch?v=7XtjtwdY6vU
http://www.youtube.com/watch?v=viYh-fqwya8
Old Sep 24, 2011 | 08:24 PM
Ralphbf's Avatar
Ralphbf
Tunnel ram and a single 4 will get pretty good economy on the freeway also. Plus they are easy to tune.
Had one on a 56 Chevy and loved it.
They do have a power band that you can feel.
327, 4 speed and 4.56's in 1972.
Old Sep 24, 2011 | 09:12 PM
Tim H's Avatar
Tim H
Maybe in a 63 ChevyII
Old Sep 24, 2011 | 10:44 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
They can work great on the street if you get the rigth one and do some tuning. Usually a LOT of timing helps response.
I'd use bigger carbs than either of those though even on a 383. At least some 600's...but I'd also use something besides a hyd cam too and use a little RPM.
JIM
Old Sep 25, 2011 | 09:57 AM
Ganey's Avatar
Ganey
A 383 is great. A tunnel ram & thumper cam sounds like a poser setup instead of perf.- not rec.!
I ran a tunnel ram w/ 2 4s on a BB in a street legal race car.
Old Sep 25, 2011 | 11:48 AM
Ralphbf's Avatar
Ralphbf
What kind of driving are you planning on doing?
How about a single 750cfm Carb. instead of duels.
Old Sep 25, 2011 | 01:18 PM
427Hotrod's Avatar
427Hotrod
It's funny on the Thumpr cams. Probably not the best marketing message for true hot rod folks...but when you look at what they actually are..there are some applications where they can work very well. I see folks spec out a custom cam...you can see the trend is often just like a Thumpr....but they would never admit it.
Thumpr's are generally relatively aggressive intake lobes with a much larger/softer exhaust lobe (N20 cam or one that you want a lot o RPM out of?)...but then they put it on a real tight LSA and create a lot of overlap. That creates the nasty idle sound...and manners....but that's pretty much what folks have done with a lot of big cams anyway.
Tight LSA's can do neat stuff in the right place....they've been doing it that way for years and years...just someone came up with a marketing name for it.
JIM
To tunnel ram
