No Air!!
Old Mar 31, 2011 | 08:22 PM
trainor's Avatar
trainor
Default No Air!!
In my 75, when I turn the heater control to defrost or heater it works fine. But when I put it on AC or vent, bi-level it won't blow any air. I'm getting ready to put my stock ac compressor in and am trying to figure out if there is a specific actuator or fuse for those vents. Any body had this problem? Any help will be appreciated as it is 84 here today. Thanks
Old Mar 31, 2011 | 08:28 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Where is here?
Old Mar 31, 2011 | 08:37 PM
BPHORSEGUY's Avatar
BPHORSEGUY
When my '77 was stuck on heat, no defrost,vent or air it was a broken nipple on the back of the heater control panel causing a vacuum leak. You could here it after turning off the engine!
trainor's Avatar
trainor
Originally Posted by BPHORSEGUY
Where is here?
Bishop,Ca. Mule capitol of the world. Now can ya hep me with my problem?
Old Mar 31, 2011 | 11:33 PM
...Roger...'s Avatar
...Roger...
When you say "won't blow any air" ,does that mean the fan quits in those positions or the fan continues to blow but won't come out the vents ?
Old Apr 1, 2011 | 12:09 AM
trainor's Avatar
trainor
Yes, fan continues to blow but won't come out the vents. Any Ideas?
Old Apr 1, 2011 | 12:24 AM
...Roger...
Sounds like a vacuum problem. If there is NO vacuum getting to the AC control the default is for all air to come out the lower heater outlet but you said you get air out of the defrost so NO vacuum is probably out.
Wilcox site has the AC/heater vacuum schematics ,you might look at those.
A bad actuator,hose off or leaking rotary valve could cause your problem.
Old Apr 1, 2011 | 12:26 AM
...Roger...
Here is one for a 74
http://willcoxcorvette.com/repairand...lp.php?hID=202
To No Air!!
