GM ring and pinion gear question
Old Apr 16, 2002 | 08:00 PM
TonyQT's Avatar
TonyQT
Default GM ring and pinion gear question
Just picked up a GM ring and pinion gear set. Can someone help me out as to what gear ratio is and what it will fit in. The ring has 39 teeth and the pinion has 11. The ring has: GM 3853010 11:39 10 66 and the pinion has: 66 3853008-11-39 GM. Thanks for your help.
Old Apr 16, 2002 | 08:13 PM
Gordonm's Avatar
Gordonm
Default Re: GM ring and pinion gear question (TonyQT)
That looks like a 3.55 set. I would check to see if they are Corvette gears. The 3.55 I have listed for Vettes is 32 and 9
Old Apr 16, 2002 | 08:59 PM
gerry c's Avatar
gerry c
since you have a computer in front of you, ratio is easy. devide 39 by 11 and you get 3.5454... that is your ratio.
What it is from is another question.
Old Apr 16, 2002 | 09:45 PM
redvetracr's Avatar
redvetracr
According to my P&A 30B 1974 version the numbers should be 3783188 and 3885943 ...redvetracr
To GM ring and pinion gear question
