Air in coolant system
Old Apr 17, 2002 | 09:09 AM
xfactor974's Avatar
xfactor974
Default Air in coolant system
How do I "burp" it out?
Old Apr 17, 2002 | 11:30 AM
zwede's Avatar
zwede
Default Re: Air in coolant system (xfactor974)
It should work its way out by itself after a few heat cycles. Turning the heater on may help.
Old Apr 17, 2002 | 12:32 PM
FeedVaal's Avatar
FeedVaal
I've found it helps to have the front end up on stands or ramps.
Old Apr 17, 2002 | 02:05 PM
bigvette1's Avatar
bigvette1
Fill it up to about 4" below the top of the radiator and let it idle until good and warm. Light reving will help move the coolant, but watch out if you have a big air bubble. Let it cool down, full up the radiator towards the top, fill the overflow tank to max line cap it and run it. The heating and cooling process wil purge the air out and take into the system what it needs from the overflow tank when it cools. For a couple of days check the level in the tank.
To Air in coolant system
