Header gasket
Old Apr 6, 2011 | 07:31 PM
Fastclient's Avatar
Fastclient
Default Header gasket
Did a little searching and found different schools of thought on the subject (imagine that) My question is when installing new header gaskets do I match the square port on the head which appears to be about 1 3/8" across or match the round exhaust pipe on the header? (or does it really matter?)Thanks!
Old Apr 7, 2011 | 09:38 PM
Jack Wood's Avatar
Jack Wood
Default As long as the gasket doesn't restrict the exhaust flow...
You might create a sealing problem if you try a gasket with only a small amount of material in the corners or at the bolt holes. You're reaching for a small amount of flow anyway. Buy some heads with round exhaust ports, match them up and be done with it.
Old Apr 7, 2011 | 11:30 PM
Vette5.5's Avatar
Vette5.5
Actually sound's like you may have the wrong header's for your application, and gasket leak's are not a fun thing. If the header flanges have raised surfaces around the tube's I've had good luck with Mr Gasket Pro Seal's, as usually no need to re-torque them. If the flange is flat, copper's with a bead work well, but important the port's properly match up. You may want to test fit, before bolting everything together.
To Header gasket
