Engine Rebuilding ideas
Old Apr 7, 2011 | 09:09 PM
S1NE5TER's Avatar
S1NE5TER
Default Engine Rebuilding ideas
Hey guys,
This weekend will be the start of my 73 project and I'am gonna rebuild the engine.
It's an original 350 L-48. i want to increase the power of the engine. Does anybody have any ideas how i could increase the performance. Nothing too crazy and expensive. I don't want to waste my entire budget for the restoration on the engine itself.
Old Apr 7, 2011 | 09:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
What budget and expectations?
Old Apr 8, 2011 | 11:44 AM
S1NE5TER's Avatar
S1NE5TER
back than the L-48 had 190 hp stock, so i would like to increase it to 200 at least. budget wise i don't want to spend more than $4000. this is my first restoration so i don't want to spend alot for my first project.
Old Apr 8, 2011 | 12:04 PM
hugie82's Avatar
hugie82
That's a good budget
383 rotating assembly and you can't go wrong topping it off with Summit alum. heads.
With machine and assembly work you will be well below your limit
Old Apr 8, 2011 | 01:43 PM
S1NE5TER's Avatar
S1NE5TER
For the 383 rotating assembly, would it all have to be done by a professional or can I do it myself?
Old Apr 8, 2011 | 02:48 PM
dugcyn's Avatar
dugcyn
just my two cents.
if you want a stroker, go crate and keep your numbers match on the side.
or rebuild. bore and machine work as needed, pop up pistons near 10:1 port-polish stock heads, good alum intake (search forum) and healthy 650 cfm carb and mild cam. your wallet wont be drained too much and you will get near if not over 300 hp. that is without any smog. oh and you will want either to breath so dont forget headers and 2.5-3. exhaust.
Old Apr 8, 2011 | 04:42 PM
volition's Avatar
volition
Well, you can buy the GM Performance 290hp engine from Summit Racing for $2000.
People will harp on it for this and that but here's the facts:
NEW engine. Everything is NEW. Not a rebuild. The engine is a COMPLETE long block and includes even the oil pan, valve covers, timing cover etc.
And since you are using it as a direct replacement it carries a 3 year, 100,000 mile warranty from GM.
I don't think you can beat that deal anywhere.
Shop around, you won't find a better deal for 290hp.
Old Apr 8, 2011 | 08:55 PM
S1NE5TER's Avatar
S1NE5TER
I'm a bit confused about the 383 rotating assembly....What exactly do you have to do to convert the 350 to a 383?
Old Apr 8, 2011 | 09:19 PM
tnovot's Avatar
tnovot
Is your $4000 budget for the entire restoration or just for the engine?
If for the whole car, a 290 hp crate like volition said is a good choice.
If just for the engine, a 383 is a 350 bored out .030 with a crankshaft from a 400 small block and will take a good chunk of your budget because of machine work, new pistons, etc.
Terry
Old Apr 9, 2011 | 01:40 PM
dochorsepower's Avatar
dochorsepower
Definitely get rid of the stock heads. Go for new technology fast-burn style heads from various sources or GM. With the fast-burn heads you can run 10:1 compression for a very responsive engine. Then don't forget the one-piece oil pan gasket, no more drips on the garage floor. If you go for the 383, spend the money for a good quality new forged crank, not a cheap Chinese casting.
Old Apr 10, 2011 | 12:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont need domed pistons to get 10:1 with a 383 or a 350.
Stroking it requires some extra clearancing/mockup work best left to a pro...ditch the stock heads if you can. no reason to not use the original block imo. If you internally balance it noone will ever know its bigger than a 350. Youll love it.
Even if they did deck the block and lost the #s its not a big deal with a '73
To Engine Rebuilding ideas
