Cut-pile or nylon loop.
Old Apr 9, 2011 | 01:40 PM
sakins.02vert's Avatar
sakins.02vert
Default Cut-pile or nylon loop.
I'm going to put new carpet in my 76 L82.
Eckler's has 15% off this weekend and two options:
http://www.ecklers.com/interior-part...rpet-sets.html
Which is best?
Old Apr 9, 2011 | 05:05 PM
6t9427's Avatar
6t9427
Which is best?
I'm going back to loop pile because it is what was originally used in 69. It wears really well IMO.
The cut pile that was in the car lost a lot of fibers in the wear area making it look like it was going bald . Could have been the quality of replacement cut pile in the early 80's.
Old Apr 9, 2011 | 05:11 PM
rcread's Avatar
rcread
I went with loop because I prefer the retro look and it wears better. Cut pile is more luxurious and looks more upscale but you will want to cover it with some good floor mats.
Old Apr 9, 2011 | 05:18 PM
Michael B.'s Avatar
Michael B.
I was under the impression that loop was for basic interior trim cars, and cut was for optional up level interior trim cars. If a Stingray had the wood look inserts it had cut pile carpet as well.
At least to my understanding that is how it went.
Old Apr 9, 2011 | 06:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
All cars with Standard interior from 1970-1976 used loop carpet and those with deluxe interior used cut pile. While cut pile looks better, the loop is more durable.
We have the carpets on sale to forum members only at this link.
http://willcoxcorvette.com/advanced_...eywords=carpet
ACC Brand 209.56
Pro Choice Brand 220.00 includes a heat barrier.
Old Apr 10, 2011 | 06:10 AM
riverracer au's Avatar
riverracer au
can someone please show me the different types of carpet, cut-pile and nylon loop, up close?
not sure what you mean by the cut plie.
also what is the 80/20 loop they talk about?
Old Apr 10, 2011 | 09:54 AM
0Willcox Corvette
Former Vendor
River-
No problem.. Below you will see the factory color chart for the 1972 from ACC's samples.
Loop or as it's called 80/20 carpet only came in cars with standard interior from 1970-1976.
Cut pile was only in cars with deluxe interior from 1970-1976. In 1977 to 1982 all cars had cutpile.
So, if you have leather seat covers and carpet on your door panels you would need cut pile, and if you have vinyl seat covers and no carpet at the bottom of your door panel it would be loop.
Hope this helps..
Willcox
Old Apr 10, 2011 | 12:04 PM
sakins.02vert
"Pro Choice Brand 220.00 includes a heat barrier."
What do you recommend for a sound barrier?
I'd like both.
Old Apr 10, 2011 | 08:48 PM
0Willcox Corvette
Former Vendor
Give me a sec.. I have a link that is turned off on the site.. then I'll post it..
Old Apr 10, 2011 | 09:02 PM
0Willcox Corvette
Former Vendor
Ok.. what I did was move the deadener from the retail side to the forum special section. The price shown on this is the price you would pay but compared to the 256.00 retail price its a steal and the same stuff we install here in our own shop.
http://willcoxcorvette.com/product_i...ducts_id=27037
Old Apr 13, 2011 | 04:32 PM
sakins.02vert
Thanks Willcox.
trying to determine if deadener is going to help my noise problem enough to be worth it. I'm getting mixed opinions.
Old Apr 13, 2011 | 05:01 PM
mar's Avatar
mar
Having gone thru installing new carpet in my 74 coupe, I would go with the thin, adhesive backed tiles for sound and heat on the floor and in the back. Use the 1/4" foil-backed stuff for the sides of the tunnel. Otherwise it bulks out the carpet too much especially where the jute padding is applied on the fronts. OR: get the carpet without the jute applied and go with 1/4" foil backed foam. If your are going to get in your doors the tile stuff is good against the outside door shells to help deaden sound. Works wonders actually, but is expensive - why, because it works. Also keep in mind that any padding under the gas pedal restricts the linkage travel!
Old Apr 13, 2011 | 09:09 PM
sakins.02vert
Great feedback thanks.
To Cut-pile or nylon loop.
