Drive shaft installation
Old Apr 10, 2011 | 09:44 AM
mvmondello's Avatar
mvmondello
1st Gear
Default Drive shaft installation
Gents,
About to install drive shaft but did not notice which end went into the transmission and which went into the differential. For balance reasons, does it matter?
[IMG]C:\Users\Mark\Pictures\Corvette Rebuild\IMG_1098[/IMG]
This is my first post, don't know if the picture of drive shaft will load, if it does, can you tell from this picture?
Thanks!
Old Apr 10, 2011 | 12:16 PM
Timsride's Avatar
Timsride
The picture didnt load. But Im pretty sure it doesnt matter which way the drive shaft goes in. It will be dependant on the U joints. I cant remember if they are the same size or not, but you want to make sure the bearing caps seat in fully or you will have vibration problems.
Old Apr 10, 2011 | 12:27 PM
BKbroiler's Avatar
BKbroiler
The driveshaft can be installed either way.
To Drive shaft installation
