Replace heater/AC blower motor/fan
Also, new 'repop' motors come in different configurations. The cheapo versions have about 1/2 the motor windings that the original motors had...and they are relatively inexpensive when compared with a 'direct' replacement. The auto store folks won't tell you that. But, you can ask if they have a "heavy duty" replacement and compare the two units. They will be vastly different in magnet/winding design.
For the trouble you will be going to for making this change, buy a high quality upgraded motor, if you buy one at the auto parts store.
- Ron
just made a small "Y" jumper lead that i placed in between the fan and the original lead
female socket ===== male spade
heavier wire with ring terminal
just reached in under the fender and removed the ground lead from the fan
placed my new jumper in, reconnected the original ground wire to the short lead
then the extra heavier lead i connected to the wiper actuator mount
had the fan on without the extra wire, then earthed the new wire and you could hear the difference
just tucked it in amongst the vacuum hoses to the relay
There was not enough beer for a day like this.
And why that wiper supplementary ground? Will any nearby ground (e.g. heater core firewall stud) do the job?
But the thread has been interesting and people may be on to something.
Have you just run a 12-gauge from the fan motor to a frame ground and left the wiring harness ground vacant?
it may be a pain in the butt, but this is a worthwhile upgrade.
