Heat Riser Question
Old Apr 10, 2011 | 06:21 PM
ted13b's Avatar
ted13b
Default Heat Riser Question
Finally finishing the insall of a new CC dual exhaust on my 7 L48 auto. The AIM seems to show the heat riser mounting with it's flat side up with no gasket between the heat riser valve and the exhaust manifold. The exhaust then bolts up to the tapered seat side of the heat riser. Is this correct, no seal between the heat riser and the manifold?
Old Apr 10, 2011 | 06:44 PM
doctorgene's Avatar
doctorgene
Yes Sir; I have a gasket between mine, but maybe they didn't put one in back then. I have never tried it without, to much trouble to change if it leaked. Have a nice one. Gene
Old Apr 10, 2011 | 06:49 PM
mikep3's Avatar
mikep3
Corvette Central has this picture of the heat riser with the gasket.
If you have a heat riser and not a spacer/eliminator then:
Exhaust Header, Three Hole Gasket, Heat Riser and Exaust Pipe.
http://www.parts123.com/parts123/yb....5Z5Z50000050G#
Old Apr 10, 2011 | 09:17 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I've had the front crossover pipes off both of my 79s and my 78SA over the last few years to replace oil pan gaskets. No gaskets on the heatrisers.
BUT, gaskets are offered for a few things that didn't originally have gaskets.....
exhaust manifolds
cat convertors
heatrisers
Nothing wrong with using them. I could use them on my cat convertors
edit....check out the diagram in the CC link above.
up to 74 used a gasket, 75-79 didn't.
Old Apr 10, 2011 | 09:23 PM
gcusmano74's Avatar
gcusmano74
You will be happier if you put a gasket between the manifold and the heat riser.
To Heat Riser Question
