No electrical power.
Old Apr 11, 2011 | 06:10 PM
JimE's Avatar
JimE
Default No electrical power.
My friend is getting his 69 out of storage & I was giving him a hand.
The battery has been out of the car on a trickle charger, so we took it had it checked and fully charged, the battery is good. We put the battery in hit the key and nothing, there is no power in the car what so-ever nothing it is dead,not a light not a gauge nothing. The car is a small block automatic. Any thoughts.
Old Apr 11, 2011 | 07:39 PM
Peterbuilt's Avatar
Peterbuilt
Start by checking the battery - terminal and the other end under the frame.
Then check the battery + and the other end on the starter.
If still no power you may have a bad fusible link.
Old Apr 11, 2011 | 08:03 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Also check the fuse link at the firewall on the driver side under the booster.
Old Apr 11, 2011 | 10:29 PM
A88FXRS's Avatar
A88FXRS
bad or coroded main ground cable at frame
To No electrical power.
