Removing Catalyst from a 1982,do I win HP?
Old Apr 17, 2002 | 06:44 PM
Pete Z's Avatar
Pete Z
Default Removing Catalyst from a 1982,do I win HP?
It is legal here to remove the catalyst from my 1982,and make it a dual system.
Do I win any HP by just removing the catalyst,and how much will a dual system give me? (all using the stock headers,I will put on better ones in the future,but there are more important things to do with my money at the moment...... :( )
Old Apr 17, 2002 | 06:54 PM
zwede's Avatar
zwede
Default Re: Removing Catalyst from a 1982,do I win HP? (Pete Z)
If you are still running the factory cat from 1982, yes, you will gain a noticable amount of power. The old cats from the early 80's were quite restricitve. New cats (late 80's and up) usually don't rob any noticable power. I've seen tests were newer cats only cost 2-4 hp on a 500 hp motor!
Old Apr 17, 2002 | 07:07 PM
page62's Avatar
page62
What sort of emissions inspections do they have in the Netherlands?
Old Apr 17, 2002 | 07:12 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Removing Catalyst from a 1982,do I win HP? (page62)
The inspecyion here is a joke. Just measuring CO values and if it's below 5% it's okay.
Pete, I ran a full 2&3/4"true dual system w/ borla's, no cats & full length headers. Never had a problem passing emissions.. remove the cat. It WILL sound a little like a tin can.
Marck
Old Apr 17, 2002 | 07:13 PM
Monty's Avatar
Monty
When my '82 was "stock", the first thing I did was add tubular headers a true dual exhaust, without convertors. Honestly, I didn't notice any change. I didn't start seeing noticeable improvements in power to I reworked and opened up the manifold. With half the area of your intake runner blocked by the Crossfire manifold you're chasing your tail, in my opinion. In the case of the Crossfire motor, I'd start on the intake side first.
Old Apr 17, 2002 | 07:30 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Removing Catalyst from a 1982,do I win HP? (Monty)
Pete,
Monty is right.. the intake is really really restrictive. I have a lot of goodies lying around. You're always welcome to come & sniff around in the parts bin.
Marck
Old Apr 18, 2002 | 02:26 AM
Pete Z's Avatar
Pete Z
Default Re: Removing Catalyst from a 1982,do I win HP? (Twinnie)
You can expect me one of these days Marck,but I'm waiting on next months pay check...... :lol:
But serious,I'm busy changing the basics now,(tires,filters,plugs,you name it) and after that I sure come over to your place,if only to see your engine! :cool:
:cheers:
Old Apr 18, 2002 | 03:42 PM
ZD75blue's Avatar
ZD75blue
I started typing about if ya tune your carb and timing you will probably have more power then you had before...
Then i realised ya had an 82 with the computer controlled gizmoes and that stuff...
Not alot of help from me :jester
Old Apr 18, 2002 | 04:45 PM
Twin_Turbo's Avatar
Twin_Turbo
Pete,
You're welcome :D (to leave behind your paycheck.. hahahah :jester )
Marck
Old Apr 18, 2002 | 05:21 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
PeteZ, you need to take Twinnie up on that offer, he knows the Crossfire just about as good as anyone. He probably has all sorts of go fast parts laying around in his junk bin! :D If anyone in the Netherlands can put some zoom in your Crossfire, Twinnie can.
Old Apr 18, 2002 | 06:28 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Default Re: Removing Catalyst from a 1982,do I win HP? (Smokehouse69)
:yesnod:
To Removing Catalyst from a 1982,do I win HP?
